Question about Alesis Music
How to hook up alesis air fx to 16channel makie mixer what jack it goes into
How to hook alesis air fx to makie 16channel mixer what input i put the air fx in to control the whole mixer befor it goes into the computer for record/i have stero cords red/white some other connectors too where does it go into the mixer
  • one2maintain May 20, 2009
    thanks very very much
    President:
  • 1,138 Answers
Go to http://www.zzounds.com/item-ALEAIRFX.Under the picture you will see About This Product. Click on DOCs and you can download the manuals for it. Read the manual carefully and it is explained very well. Use your mixer manual to get the best set up. I would recommend using it in an FX loop that lets you mix the individual channels FX into the output you have hooked up to your computer.
Posted on May 19, 2009
How do i connect a monitor to the 1202FX mixer
Hi, you can use the Control Room outputs to give you an additional output with it's own level control but of you want a separate "mix" rather that overall level you could try the FX send & use the FX controls per channel to set the mix - depends how / if you are using the FX of course! - Else upgrade to a mixer with 2 Aux sends - use one for FX & the other for monitor :-) e.g. some of the Alesis do this! 'Good Luck!
Dec 21, 2014 | Behringer Xenyx 1202fx Mixer 12 Input 2...
RESET ON BOARD FX
The clip light means your input signal is too high and distorting. Turn down the attenuator(input) knob until it goes out, use the channel volume for level. It should have a knob for the names of the effect selection.
Mar 22, 2014 | Behringer XENYX 2442FX Mixer
What do you hook up first, mixer or power amp oreffects in a rack system?
Effects plug into mixer, mixer plugs into power amp. Others may want the mixer and the effects plugged into the power amp for the most available inputs. (when multiple inputs are available.)
Effects and mixer are a line level output and the mixer can be considered a line level input as well. A mic mixer has gain amplifiers for the inputs that are below line level such as unamplied microphones. It is possible to parse to absurdity, but the gist of it is above assuming you do not want to apply the same effects to everything all at once.
Feb 06, 2012 | Soundcraft Efx12 12-channel Mixer With...
I have a mackie fx 8 mixer connected to two thump 15 " speakers. i want to add a set of base non- powered speakers with power amp to my fx 8. what are the connections?
Balanced audio interconnects (either XLR or TRS cables from the mixer and then balanced audio interconnects from the amp daisy chain inputs to the existing speaker inputs. If the amps do not have linked input jacks, then use TRS type WYE connectors at the inputs. Then use speaker rated cables from the amps to the passive speakers.
Aug 12, 2011 | Mackie ProFX8 Professional Compact Mixer
I have a behringer eurorack ub1204fx hooked up to a bose L1. I can't seem to get the reverb to work
you have to set three gain controls to pass the FX into the mix. The FX send gain for each input channel, the FX fader which sends the FX mix to the effects unit, and finaly the gain that sends the FX output to the mix. Depending on which effect you choose, some are very subtle.
Aug 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Can't route effects to two channels of my mixer. If I plug into input 1 of my power amp, I have effects. If i plug into input 2 of my power amp, I get no effects. I tried both Crown and QSC power amps. ...
The power amp is the final stage - the last output from the mixer goes to the power amps.
Its a routing problem - some mixers only allow certain routing and this could be affecting your FX routes.
All the FX - internal or outboard come before power.
Check the manual Check the aux send and returns Check if you need need stereo plugs for the send and return of FX.
Get back if still stuck.
Feb 26, 2011 | Lexicon MX400XL Dual Stereo/Surround...
I record a podcast with the 8track multimix usb Alesis. I use one XLR - Jack input and the rest XLR-XLR. There are 4 inputs being used in total. I seem to be getting alot of hiss and buzzing from the...
What is the source of the input signals? These need to be balanced lines and the sources need to be balanced. If you happen to be using condenser mics, you probably haven't turned on the Phantom Power in the mixer. If you are recording from a sound card in the PC, those have a lot of noise and are unbalanced and you have to use DI's with ground lift ahead of this mixer.
Feb 08, 2011 | Alesis Multimix 8 USB 2.0 8-channel Mixer
Lost my booklet, how do i setup and fx pedal to mixer. It has outputs A/Mono and B and inputs A/Mono and B
Go to Google. Copy-paste the following in the search window:
PMP1000/PMP3000/PMP5000
Select the one that should be at the top that says Owner's manual for these three PMP's.
Print yourself the manual.
If you just want the pedal to turn on/off the FX within the PMP3000, just plug a switch pedal into the jack on the top labeled "Foot Sw"'
If you are trying to insert an external FX unit, best to read the manual I have sent the link to. You may have to OK loading the PDF file as some popup blockers will require you say it is OK to download.
Jan 10, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Alesis sr16: How do you hook it up??
Come from the main outputs, probably labeled L/mono and R and connect those to your mixer for your audio system on either stereo mix input OR two two inputs that are panned opposite.. DO NOT connect this to a consumer type stereo system as you may blow the speakers or amp. Consumer stuff just isn't able to take output from music equipment such as this UNLESS the volume is kept very low.
May 23, 2010 | Alesis Sr 16 Stereo Drum Machine
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Music Logo
178 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Will Halftowaite
Are you an Alesis Music Expert? Answer questions, earn points and help others
