Question about RCA CA 32" Cla 720p 60Hz LED TV LED32C33RQ Black 30 to 39 in
My rca flat screen tv has a black and white picture
My tv has a black and white picture when watching tv but the menu screen has color.
SOURCE: help rca 46inch
I have the same problem using HDMI cable, I was able to get it working using composite or RCA
cables. I still cant get it working on none of the 3 hdmi inputs
Posted on Nov 07, 2008
VOTIT
  • 2071 Answers
SOURCE: No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 29, 2009
SOURCE: When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
Thank you ryolkowski!!!! We just tried your solution and MAN it worked like a damn. We were all ready to make a trip to the city to get a new tv, an expense we just didn't need right now. You made our day. I can't thank you enough. jabo
Posted on Aug 02, 2009
tbirdfan1
  • 3051 Answers
SOURCE: have sound but no picture on my RCA flat screen.
Hello there:
they have been having these problems for some time now they currently incorporating a new board design that will replace the existing board that is supposed to me more compatable with several models of this tv ok
Best regards michael
Posted on Dec 10, 2009
Testimonial: "Thanks Michael! I realized this must be an big problem, RCA is next to impossible to get on the phone. I'm still trying..."
budmrtn
  • 11361 Answers
SOURCE: RCA L26WD21 No picture/white screen but still have sound
It sounds like the LCD controller board went out, look inside to see if the cable may have come off the LCD controller board. You can look and see what it looks like here: http://www.shopjimmy.com/catalogsearch/result/?q=RCA+L26WD21+
Please post back what you find.
Posted on Dec 25, 2009
My RCA 32" TV 2001 is black and white but the menu
Ours had a problem like that. The digibox and the dvd player (anything plugged in with a SCART lead) only played in black and white but the tv menu screen was in colour.
Also anything plugged in with those three little thingies, the red/yellow/white thingies, played in colour so we just bought a converter between SCART and the three thingies.
Sorry for how useless this was, I'm not great with all the technical language. Hope it helped in some way.
Dec 04, 2010 | RCA F32672SB 32" TV
Color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Jul 23, 2010 | RCA F19431 19" TV
I just purchased this tv. I had no trouble hooking up the satalite cable box but When I hooked up the dvd player the picture is only in black and white. How do I fix this?
Are you using component video (red/blue/green) rca jacks, or composite video input (yellow) rca jack? You need to match the color but watch out and do not get confused with the red and white RCA for audio.
Dec 17, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
52 inch RCA big screen
check all connections and different sources(dvd, vcr, antenna) to make sure that it is the tv. otherwise i would say call a technician because you could be in for some extensive troubleshooting
Jan 25, 2008 | RCA P52960 52" Rear Projection Television
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
Rca p52771at - dark picture
Sounds like a bad screen asy,part number 204809,must use the generic,or you could have weak tubes,if so you may just need to turn up the screen drives,this part is located in the right top of the set with the back removed,if no cracks are present adj. the three marked screen's,turn the color all the way down in your menu and adj. for a black and white picture.
Oct 07, 2006 | RCA P52771AT 52" Rear Projection...
RCA CA 32" Cla 720p 60Hz LED TV LED32C33RQ Black 30 to 39 in Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
