Question about Panasonic NN-P294SF Microwave Oven
ERROR CODE H85
STARTS THEN STOPS AFTER 10-60 SECONDS
Samsung microwave se error
see the video attached. God bless you
Dec 09, 2013 | Samsung MS1040BB Microwave Oven
Error code -FS- on display with 3 long beeps
Hello :
Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds you need to replace humidity sensor .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Model 72180883400
F-9 error code indicates a defective control board, inverter or line voltage too high. f the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
Sep 01, 2008 | Kenmore 62702 Microwave Oven
Microwave beeps, error codes display and keypad stops working
It sound like you have a bad keypad or controls.
Is it possible that moisture from the sponge is getting into the controls?
You might contact the manufacturer to see if there might be a recall. I've seen keypad recalls in the past.
Anytime the keypad is suspected of coming on by itself, the oven should be unplugged when not in use.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 01, 2008 | Cuisinart CMW-100 Microwave Oven
F7 Error code
Please reply back with your model number so we can help you.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
May 30, 2008 | Microwave Ovens
Neff 5474.0/gb. When microwave time and power is set, after pressing the start button,the microwave works for about 2 seconds then stops and the fan starts. the error code H 95 shows on display. The...
After a bit of digging, it appears to be an issue with the door not being closed correctly (or at least the it thinks is isn't.
Ref:http://www.sampfordixl.com.au/gaggenau/upload/BM221130_instr.pdf
I know its a different model but the functionality is identical...
Apr 27, 2008 | Microwave Ovens
F-9
Need to know the entire model # on the microwave.
Oct 05, 2007 | Microwave Ovens
Microwave Ovens Logo
26 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
