Question about Cuisinart DCC-2000
Cuisinart coffeemaker won't make a full pot? - Cuisinart DCC-2000
  • 12 Answers
SOURCE: Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Posted on Dec 27, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Posted on Dec 30, 2008
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Posted on Nov 16, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Self Clean Button
Unplug the coffeemaker for 1 hour or longer - it should reset the coffee maker and get rid of that self-clean light.
-Tha Mp3 doctor
Posted on Feb 15, 2009
freetek
  • 5568 Answers
SOURCE: Cuisinart COD 4000 coffeemaker
Just a comment; most of the coffee maker failures are caused by the premature failure of a thermal fuse that is intended to prevent fire in case the main heater doesn't turn off as it should. Unfortunately, most of these parts come from China and are very poorly made so the point at which they 'protect' is pretty unpredictable, many of them failing at a much lower temperature than necessary. The second most common failure is the thermal switch that cycles the main heater element; these are bimetallic switches that grow 'tired' and the point at which they open and close again gets wider apart until it can take an hour for a 12-cup pot to finish brewing.
Posted on Jul 15, 2009
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
The water isn't coming out of my cuisinart coffeemaker model PG-18423! It's on but what do I do?
Age? Warranty? Highly likely the electrical connections and controls internal are bad. Probably time to replace with a lightly used replacement. It may be less than repair.
May 02, 2015 | Cuisinart Coffee Makers & Espresso...
Cuisinart coffe maker does not allow water in
Common problem, it is hard water issue, these coffee makers do not handle even slightly hard water as deposits build up quickly blocking water flow to element. Try one of the many coffee pot cleaners, but if it is as bad as described, may not be enough to clean out coils.
CERACOAT-NANOTECH.com
Apr 21, 2015 | Cuisinart Coffee Makers & Espresso...
Coffeemaker shuts off in the auto brew cycle
Your Cuisinart coffee maker probably is defective, though new.
Jan 10, 2018 | Cuisinart Chw-12 Coffee Plus 12-cup...
After brewing coffee does not stay hot.
Unplug the coffeemaker for one full hour.
When you replug it, go to Auto-Off - change the time from "2:00" to "4:00", and then brew another pot. Immediately after the brewing is done, set the coffeemaker back to Auto-Off and see if your problem is resolved.
If not, it may have deeper problems. These coffeemakers have a 3-year warranty - call Cuisinart to see if you are still in-warranty.
-Tha Mp3 Doctor
Jan 31, 2009 | Cuisinart DCC-1200 Coffee Maker
Self Clean Button
-Tha Mp3 doctor
Jan 24, 2009 | Cuisinart Coffeemakers
Cusinart DGB 550BK coffee maker not working properly
Cuisinart Coffeemaker Decalcification Process
-Tha Mp3 Doctor
Jan 12, 2009 | Cuisinart Coffeemakers
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
