Question about Samsung RESF3330D Electric Kitchen Range
Samsung FTQ352IWUX taking too long to preheat
I inserted the temperature and it is taking 2 plus hours to preheat to that level. Any Ideas why?
Control panel is stuck on 5Ab
Sabbath Mode.
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
May 16, 2011 | Ovens
Is there a design flaw in the Samsung ranges; i.e. thermostat is located in center between elements - not in one corner as most ranges? I'm having my range replaced with another of same model; but I'm...
Any range with a built-in element ( the bottom element not exposed) takes on average 15 to 20 min to preheat. It's not only the samsung ranges.
Mar 14, 2011 | Samsung Kitchen Ranges
My stove and oven froze with an error of 5ab6 bath or 6ath wont do anything
Sabbath feature.
These stoves are programmed for the sabbath.
To
ARROW pad.
"3".
shut-off.
Other Displays:
stay on USE.
Jan 22, 2011 | Maytag MGR6775 Stainless Steel Kitchen...
I wanted to change the time hour. I pushed clock and up arrow at a time and the clock is showing 5 AB. The screen is frozen. I can't use any options. How could I get it back to normal? Thank you for your...
To
ARROW pad.
"3".
shut-off.
Other Displays:
stay on USE.
Nov 20, 2010 | Magic Chef 9112 Gas Double Oven
How do I activate the Shabbos (Sabbath) Mode.
To
ARROW pad.
"3".
shut-off.
Oct 22, 2010 | Maytag MER6772 Gemini Electric Kitchen...
How do i get rid of a 5a6 6ath maytag stove on screen. I have unplugged and replugged after several minutes - still oven does not function at all...help!!!
To
ARROW pad.
"3".
shut-off.
Other Displays:
stay on USE.
Aug 18, 2010 | Maytag MER5775Q Electric Kitchen Range
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
Oven does not get to temp when it says its preheated
More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
Feb 10, 2010 | GE Ovens
Hotpoint RGB745 Gas Kitchen Range
try changing the oven sensor its in the oven looks like a small rod coming out you need to remove 2 phillip screws the take it out
Jun 08, 2007 | Hotpoint RGB745 Gas Kitchen Range
Samsung RESF3330D Electric Kitchen Range Logo
177 people viewed this question
Top Samsung Kitchen Ranges Experts
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
