Question about Funai Televison & Video
Funai 32" tv component not working with PS3
I recently got a PS3 and Funai 32" tv. When I originally set up my PS3, I had B&W picture and no sound. After set-up, I'm no longer getting anything on-screen. I assumed the cables were to be connected as you'd expect - lower 3 connectors, yellow, white, red - but the Funai manual suggests that the yellow one be in the top connector row for Bluray/DVD. I tried unplugging, resetting both device, nothing's working. Any advice?
  • 5568 Answers
SOURCE: LG 42'' TV has no sound but great picture. How do I get the sound?
You shouldn't need anything plugged into the accessory jacks to get local sound from your set. Go through the main setup menu and check audio settings; they may be set to turn off the internal speakers to send the sound to a home theatre that you apparently don't have. Most sets have that as a selection and supply L-R audio for an external system and mute the internal speakers.
FYI: The three connectors you mention are coded as follows:
Red - right channel audio White - left channel audio Yellow - composite video (contains synchronization signals and video)
These may be input connectors (for external VCR/DVD decks) so check your owner's guide to verify.
Posted on Nov 23, 2008
SOURCE: Connecting Wii to Emerson 37 in LCD tv
Finally found the correct point of entry to tv and correct channel on my own.
Posted on Dec 26, 2008
SOURCE: TV connections- Wii, Direct Tv and DVD palyer
Hidden switch for output coonections on back panel of dvd player.
Posted on Dec 29, 2008
  • 67 Answers
SOURCE: hdmi connector causes picture freeze
The problems with HDMI are plentiful. They are still hashing out the standards for it, and every company seems to be doing their own thing. The compatibility issues are never ending, and you may be a victim.
It sounds like the Blu-Ray and the TV are having compatibility issues. You can try changing resolution settings inside the Blu-Ray to see if it helps. If not, you might be stuck using Component cables. LG televisions are not the most well-constructed or designed tv's in the world, so if the optical output is not working, your Digital Board might have an issue, as well. Any competent TV repair shop should be able to assist you in troubleshooting and repair, if necessary.
I hope this helps you.
Posted on Dec 30, 2008
  • 335 Answers
SOURCE: DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Posted on Jan 25, 2009
I have an esa tv model EF420E. What channel does it need to go on in order to watch DVD's and play on the Xbox?
I assume you have the DVD or XBox connected to the composite video or S-video ports on the EF420E. These can only be accessed with a remote control that has an Input button. The original remote had the Input button near the middle of the remote on the right side of the remote. Pressing it allowed you to toggle between TV, Video 1, and Video 2. If you do not have the original remote or the remote's Input button doesn't work, you need a replacement remote or an universal remote with an Input button. (Many of the cheapest universal remotes don't have this feature button included.) A replacement remote is available from . They have the original remote and a guaranteed to work alternative. If you choose to get another universal remote, you may need to try multiple codes until the Input button works for your TV. (Try Funai codes, if ESA isn't a listed manufacturer.)
The ESA EF420E was built by Funai. The manual is available from Funai Service: . The direct link to the manual is .
I hope this helps.
Oct 30, 2014 | Televison & Video
Need help connecting a funai dv220fx4 to a vizio m470vse?
Sounds to me like you got the component leads correct but not the composite (video).
See in the link for downloading the manual :-)
Funai 50 years of Excellence in Consumer Electronics
Apr 23, 2014 | Vizio L37 Television
If you have a scart socket on the TV it would be much easier to use this
Sep 12, 2017 | Vizio L37 Television
Funai tv 32 inch LED
what are you using with hdmi? if you are using a laptop you must go to your speaker configuration and change it
Dec 02, 2013 | Panasonic Televison & Video
Urc-31021BG1 CODES DOES NOT WORK WITH MY EMERSON tv LC195EM82 Any other codes I can use?
Unfortunately, you probably need a newer remote. The Emerson TV was released in 2007. The manual for the LC195EM82 is available from Funai: . The URC-3021 remote was released in May 2004.
Universal remotes only have codes for devices released 6 months or more before the remote was programmed. The commands change with various generations of control boards.
You can try the Emerson and Funai codes (since Funai built the TV for the Emerson brand) but I don't think you will have any better results.
Emerson TV codes: 0154 0236 0463 0180 0178 0171 0623
Funai codes: 0180 0171
The code list and the manual for the URC-3021 are available here: . Look at the bottom of the page for the links.
I wish that I had better news for you.
Oct 05, 2011 | One For All URC-3021 Remote Control
I have a ilo 32" tv. I purchased a sentry really big universal remote and can't find the code for it. Can someone please help.
Try using the codes for "Funai". I have an Ilo TV that was handed down to me and couldn't program it to my DTV box. I looked up the origins of Ilo, and they're made by Funai. Their codes worked. If that doesn't work, then dig info on Funai. Best of luck!
Jun 17, 2009 | Sylvania LC370SL8 37 in. LCD Television
Give FUNAI a call they can walk you through the problem. There info is...
Tel :1-800-605-8453
Feb 15, 2009 | iLO IWT3206 TV
Durabrand Tv need to program universal remote
Your sets were made by a Japanese company named Funai.  No guarantee, but you might try any Sylvania, Emerson, Durabrand, Symphonic, or Funai codes listed.
If none of those work, often has original remotes at inflated prices.
Sep 29, 2008 | Televison & Video
Tv won't turn on
my funai 3216 was working ok it went off today and wont come back on iv changed the fuse in the plug with no luck iv taken the back off the tv what next please help
Jun 22, 2008 | Televison & Video
Televison & Video Logo
47 people viewed this question
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
