Question about Dell Inspiron 2200 Notebook
Inspiron 2200 Memory Module not recognised
I added a 512 MB memory module in my Inspiron 2200 expansion slot. Unfortunately the PC does not recognise the extra memory. removing and re-inserting the module did not change it. I am lost....
  • 27 Answers
Are you sure its the correct speed/type of RAM? According to Google your laptop takes PC2700 DDR RAM, ensure you are using this in both slots to avoid problems. If you have it fully inserted into the slot and nothing happens when you swtich it on then the laptop doesnt like that type of RAM and you'll need to change it.
Posted on May 17, 2009
Will 9500 GT either 512 mb or 1 gb work on intel la crosse D865GLC board..?? it has 3 pci slots 32-bit long..
Yes you can.
For 512 Mb RAM you can use a single 512 Mb memory module or two 256 Mb memory modules.
For 1 Gb RAM you can use a single 1 Gb memory module or two 512 Mb memory modules.
Apr 13, 2011 | Intel Desktop Board D865GLC (MBIND865GLC)...
Sony Vaio not recognized installed memory
Swap the modules between the slots.
If the message shanges to slot 0 not recogonized, then you have a bad memory module,
Easy fix, just get another module.
If the message does not change, then you have a problem on the mother board.
Not an easy fix, it would be cheaper to buy a 1GB module and use the good slot.
Good Luck!
Jan 24, 2010 | Sony VAIO GRV670 Notebook
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
How to install memory for T3642 eMachine
eMachines T3642 Computer takes the PC2-5300 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 1.0 GB = 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T3642 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 1.0 GB = 512 MB (removable) + 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
INSTALLATION PROCEDURE
1. Place the computer power switch in the "off " position and disconnect the AC power cord.
2. Remove the computer top cover following the instructions in the model-specific owner manual.
3. Before touching any electronic components, make sure you first touch an unpainted, grounded metal object to discharge any static electricity stored on your clothing or body.
4. Locate the memory expansion sockets on the computer motherboard. If all the sockets are full, remove smaller capacity modules to allow room for higher capacity modules.
5. The ejector tabs shown in the illustration are used to remove a module. By pushing outward on the ejector tabs, the module will pop-up from the socket and it can then be removed.
6. Handle your new module carefully; do not flex or bend the module. Always grasp the module by its edges.
7. For most installations, DDR modules can be installed in any available expansion slot. Other installations may require the memory to be installed in a particular sequence based on the modules capacity. Check your owner manual to determine the correct installation sequence for your configuration.
  • Insert the module into an available expansion socket. Note how the module is keyed to the socket. This ensures the module can be plugged into the socket one way only. Firmly press the module into position, making certain the module is completely seated in the socket. The ejector tabs at each end of the socket will automatically snap into the locked position. Repeat this procedure for any additional modules you are installing. install_ddr.gif 8. Once the module or modules have been installed, the computer top cover can be reinstalled.
    9. Plug in the AC power cord and reinstall any cables disconnected during the installation process.
    10. Turn on the computer and follow the instructions in your computer owner manual that describe the steps necessary to allow your computer to recognize the newly installed memory.
  • Oct 23, 2009 | E-Machines eMachines T3830 PC Desktop
    Memory upgrade
    What kind of laptop do you have and whats the model and model number??
    Mar 25, 2009 | Computers & Internet
    Memory module
    0 MB on-board memory expandable to 512 MB
    Two SO-DIMM slots
    SO-DIMM sockets accept 8-, 16-, 32-, 64-, 128-, and 256-MB SDRAM modules in any combination.
    Use only PC100 memory modules.
    so yeah you bought the wrong ram
    Mar 09, 2009 | Dell Inspiron E1505 Notebook
    Added memory but one memory card (Original) not recognised
    OK, according to Crucial.com your RAM does need to be installed in matched pairs.
    Here is a link for your computer information:
    http://www.crucial.com/store/listparts.aspx?model=Presario%20SR1460AN
    If you get another 512MB module and install both pair, it should work well.
    Jan 13, 2009 | Compaq Computers & Internet
    Inspiron 6400 notebook
    There are two slots for memory on that laptop and it will take a maximum of 2GB of RAM. The memory type is 1.8-V SODIMM DDR-2.
    The cover ont he bottom if the laptop is easy to access and add more memory.
    Dec 31, 2008 | Dell Inspiron 6400 Notebook
    Does my inspiron b130 laptop support s video output to my tv?
    No. INSB130 does not support S-Video. Here's the complete specs of your system:
    Processor type Intel® Pentium® M and Celeron® M
    External bus frequency (front side bus) 400 MHz or 533 MHz
    System chipset Intel 910GML Alviso
    Data bus width 64 bits DRAM bus width Dual-channel (2) 64-bit busses Flash EPROM 512 KB Graphics bus Internal PCI bus 32 bits ExpressCard controller ICH6M ExpressCard connector One ExpressCard slot 54 mm Cards supported ExpressCard/34 (34 mm)
    Expresscard/54 (54 mm)
    1.5v and 3.3v Memory module connectors Two user-accessible SODIMM connectors Memory module capacities 256 MB, 512 MB, and 1 GB each Memory type 2.8-V SODIMM DDR-2 Minimum memory 256 MB Maximum memory 2048 MB Ports and Connectors :
    Audio Microphone connector, stereo headphones/speakers connector
    Mini PCI Type IIIA Mini PCI card slot
    Modem RJ-11 port
    Network adapter RJ-45 port
    USB Three 4-pin USB 2.0-compliant connectors
    Video 15-hole connector
    Network adapter 10/100 Ethernet LAN on system board Wireless Internal Mini PCI Wi-Fi® wireless technology support
    Video Type Integrated on system board
    Video controller Intel Integrated Graphics Media Accelerator 900
    Video memory Up to 64 MB of shared memory (when less than 512 MB system memory is installed)
    Up to 128 MB of shared memory (when more than 512 MB system memory is installed)
    If this is helpful, please rate it.
    Dec 05, 2008 | Dell Inspiron B130 Notebook
    Adding more memory to my inspiron notebook
    The second slot on the 2200 is under the keyboard.
    Jul 31, 2008 | Dell Inspiron 2200 Notebook
    Dell Inspiron 2200 Notebook Logo
    124 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
