Acer Aspire 3000  PC Notebook
Broken Screen!
shared by 3 users
posted by dsoria on Oct 17, 2007
My little sister stepped on the screen and cracked it horribly, so i tried hooking up a DIFFERENT monitor (which was fairly new) i turned it on, and it WORKED! but only up to the WINDOWS XP start up screen and the blue screen that tells you its checking "disk C" once its done counting to 100, the monitor shuts off, and in the middle a blue box pops up saying "POWER SAVING" and thats ALL it will let me do. Please help. thanks.
Comment posted on Oct 17, 2007
no, whats happining when i turn on my laptop is the cracked screen and the monitor both turn on, then when i push that button, the screen attached to my laptop turns off, an the monitor is stays on, showing me the windows start up, and system check, once that finishes than, the monitor swiches to "power saving" mode, an turns off, my screen turns back on and just stays lit. but its so cracked up that theres nothing even visible in it.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by Guest on Mar 26, 2008
I have broken screen on acer 4000, so much broken, but it will litup, not any readability, I didn't try anything.
Posted by Guest on Feb 24, 2008
my screen have two scratches... i want to repair it at lowest cost
Solution #1
posted on Apr 26, 2008
Not Rated (0)
scottyfixit
Rank:Wiz Wiz
Rating: 85%, 109 votes
If you dig around in google shopping, you can find replacement LCD's. Something similar like this maybe -> http://cgi.ebay.com/Acer-Aspire-3000-15-4-WXGA-LCD-Screen-Glossy-Grade-A_W0QQitemZ160233528611QQcmdZViewItem
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Broken Screen!:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Paeroa
Rank:Wiz Wiz
Rating: 81%, 493 votes
If you look on the key board cloured blue is the FN key and a monitor looking key. (remember coloured blue) press them similtaneously your external monitor should return.  On my machine it is the FN key and F4 yours mabe the same.  Please comeback and tell me how you got on.
Comment posted on Oct 18, 2007
It has got to change and stay there by using the  Fn F4 key or similar.  I know because I am doing the same.  If the laptop comes on again continue pressing those keys until you get what you want and if it goes into power mode then change it in the control panel.
well did it work it has too........what your doing is using them like a switch hold the function down and press the other up down up down until you get the desired result.
Thank You!
Can you Help with these PC Laptops problems?
PC Laptops
radio configuration is locked in bios settings
Acer Aspire 3000 (AS3004WLCI) PC Notebook
when i start the computer it dosen't gime a response and...
where can I get instructions on replacing the bezel on a...
Acer Aspire 5610Z. Need to operate the webcam but dont...
amplion, appears like an old holiday brief case, pink...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find PC Laptop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
