Question about Onkyo Ht R530 Receiver 7.1 Surround Sound System Receiver 7 Speakers Remote
Turntable with onkyo HT-R530
Connected record player/turntable to the receiver and must turn it up 50+ to get a slight sound. should i get an adapter for phono preamp?
4 Suggested Answers
  • 319 Answers
SOURCE: Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Posted on May 07, 2008
  • 15 Answers
SOURCE: Onkyo ht-r530 Receiver troubleshooting
the 7.1 sound not all the movies has that feature and u need to emulate it, doit in the dolby digital ex and the speakers must sound.
try the volume for the SBL or SBL maybe are to low.
decrease the volume for all the speaker less the SBL, SBR and check it out.
Good Luck
Posted on Jan 12, 2009
Grubhead
  • 5047 Answers
SOURCE: Selecting phono preamp for Onkyo HT-R510
The magnetic cartridge preamp should work with the turntable, as presumably it will have a magnetic cartridge in it. The only reason that the amp states "magnetic" is that some very old turntables have ceramic cartridges which should not be connected to that terminal. Even if the turntable had a "ceramic" it could be replaced with a magnetic one!
Posted on Mar 21, 2010
MANUAL GUIDE OWNER ONKYO RECEIVER AV HT-R530
Hi Javier, you can located the owners manual at the following link, http://www.onkyousa.com/Downloads/manuals.php?source=globalnav. Note that your unit is part of the HTIB HT-S780, Thanks, JT
Aug 24, 2015 | Onkyo Audio Players & Recorders
Only plays through one front speaker when in video mode.i've tried v-1 v-2 and v-3. i'm using optical for audio
Hi Richard, please make sure that the source has been assigned to the optical connection via the setup menu or you can select the source and then press the digital input button until the display shows the optical connection where the physical connection was made on the back of the Onkyo, Thanks, JT
Apr 01, 2015 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
My receiver works fine when I plug my iPod into it, but when I plug my turntable in I can't get any sound. Any idea?
The phono cartridge on your turntable puts out a much lower level signal than your iPod. Back when turntables were popular, all receivers had a special phono input to take care of that. Your modern HK receiver does not have a phono input, so you need to get an external phono preamp. Plug the turntable outputs into the phono preamp inputs, then plug the phono preamp outputs into one of the audio inputs on the HK, like where you connected the iPod.
Oct 08, 2013 | Harman Kardon AVR 745 Receiver
I have connected Pioneer PL-990 turntable to SX-255R receiver through PHONO but get static and distortion through speakers. Manual says to connect to AUX not PHONO but cannot see AUX on receiver. Any...
You need to hook it up to another analog input other than the phono input. The record player has a built in preamp, and the receiver's phono input has a separate preamp for non-amplified players. You cannot have the two hooked to each other.
Jan 28, 2013 | Pioneer SX-255R Receiver
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
The sound is really low if i press the aux tape cd phono or vcr the sound is there but really low
Instructions:
Evaluate your current receiver. Take a look at the back-panel connections to make sure you don't have a phono input. In most cases, the phono input will be clearly marked. If the connections are not marked, look for a set of RCA-style inputs with a grounding screw next to them; this is a phono input. If there isn't a phono input on your receiver, see if you have an open set of RCA inputs. If they are all occupied by other equipment, you can disconnect one piece of equipment, buy an A/V switcher or get a new receiver--preferably one with a phono input.
2 Purchase a phono preamp. The voltage output of a turntable is much lower than those of other peripheral devices, including CD players, tape decks and game systems. Although the inputs look the same, connecting a turntable to a standard RCA audio input will result in very faint sound output, if you hear anything at all. The output of your turntable must be amplified to a level of about 150 millivolts (mVs) before it reaches the receiver, so a turntable "pre-amplifier" or phono preamp is necessary.
3. Purchase patch cables. You'll need a set to run from the preamp to your receiver. Measure how long your cables need to be, and purchase accordingly. Resist the temptation to "go cheap," because better-quality cables will provide better sound.
4. Connect the preamp into the system. First plug the preamp into an AC power outlet. Most models have a small AC-to-DC adapter built into the plug. Then connect the cables from the turntable to the preamp, and connect your new patch cables from the preamp to the receiver.
5. Adjust the gain of the phono preamp. Most models have a gain control for fine-tuning. Follow the instructions provided by the manufacturer and adjust your system accordingly.
F150 Parts.
May 27, 2012 | Audio Players & Recorders
How do I hook up a home theater system to my sansui record player? DO I need any special hook up? Where is the volume controlled?
Some make and model numbers would have helped.
A traditional turntable requires a preamp inline with it to PRE amplify and frequency-balance (*) the minute signal produced by it's cartridge. Most stereo receivers and preamps have Phono connections and internal preamplification strictly for that purpose. Lacking a Phono Preamp you will have unusuable very low, tinny sound.
* Google "riaa equalization" for some background
Some of the newer turntables come with selectable internal preamplification to solve the lack of it in modern equipment.
Volume is always handled at the electronics.
Jan 30, 2011 | Audio Players & Recorders
Onkyo Ht R530 Receiver 7.1 Surround Sound System Receiver 7 Speakers Remote Logo
37 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
