Question about Garden
Transmission stuck mahindra 4500
Tractor is stuck in 4th gear, gear shift is free but will not go into gear. Am looking for a diagram or something that will give me an idea what to do. Could it be as simple as a cotter or shear pin?
  • 86 Answers
SOURCE: Craftsman lt1000 with manual transmission,
The detent Shaft inside transmission lost its ball and spring if its working outside transmission,could be other damage .
Posted on May 09, 2009
SOURCE: DYT 4000 Lawn tractor won't start
I solved the problem after buying carb and fuel pump rebuild kits.The carb kit didn't fit anyway, but didn't need it. The problem was in the fuel filter. I had forgotten the problem happened when I ran out of gas. Inside the fuel filter is a washer held in place by a spring. Without fuel it apparently lost pressure and the washer slipped out of place about 1/2", which was enough to let all the gas through that could. The rebuild kit had a new rubber gasket. I won't let it run out of gas again.
Posted on Aug 11, 2009
mowerman1857
  • 389 Answers
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
Posted on Oct 22, 2009
wireguy212
  • 1627 Answers
SOURCE: i need a wiring diagram for a john deere 4500
What are you trying to repair?What on the tractor is not working?Copy right laws prevent me from posting the diagrams but i can help you with your problem,i have access to the diagrams you need so let me know what you need.
Posted on Jan 21, 2010
spiegela
  • 3 Answers
SOURCE: john deere 445 tractor v twin 22 hp engine, john
Where did you get it fixed for $300. Dealer wants 6 hours labor and $400 in parts. Total cost will be $1,000.
Posted on Jun 05, 2010
1984 Yamaha venture royale 1200 stuck in 4th gear
Hi, Michael and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Stuck in 4th Gear 1995 Sportster 1200 Harley Davidson Forums
ATV Connection
http://bergall.org/temp/venture/pdf/1983-1985-yamaha-venture-manual-complete-with-wiring-diagrams.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xv-owners-manuals
Feb 20, 2017 | Yamaha Royal Star Venture Motorcycles
What to do about my mahindra tractor hung in high gear
Does it shift out when the clutch is depressed? Does it have a torque multiplier? If it does, try switching the torque multiplier first.
If all else fails, the transmission may need to be opened. That's probably a "top-loader" transmission, with the shifter lever mounted to a plate bolted to the top of the transmission. That makes it really easy to get to the shift forks inside. You may just need to relocate a shift fork. Be super-careful to keep that transmission clean inside - clean off the top of the transmission REALLY WELL before you take the top cover off!
Jul 12, 2014 | Vehicle Parts & Accessories
2008 Honda CRF 250 R won't shift into 4th gear
Hi, Ludich and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://crfsonly.com/forum/viewtopic.php?t=33998
transmission 4th gear
Honda 2004 CRF250R Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CRF250R Owner Manual Competition Handbook
May 28, 2012 | 2008 Honda CRF 250 R
My CT110 is stuck in 4th gear. Runs great but won't shift out of 4th gear. Anything I can do?
Hi, John and the usual suspects are:
Honda Trail CT90 CT110 Forum
77 CT90 Stuck in Gear Honda Trail CT90 CT110 Forum
http://ct90-ct110.com/PDFs/C200_CT200_Shop_Manual.pdf
http://www.partsfish.com/page/oem-parts-for-honda
HONDA CT110 Owner Manual
May 21, 2012 | Honda CT 110 Motorcycles
Transmission?
definitely something in the tranny
Apr 15, 2009 | 2001 Volkswagen Jetta TDI
2001 Triumph Legend Stuck in 4th gear
this is most likely a bent  or broken shift fork  a broken gear cluster  or  foreign object lodged in the transmission housing  this is very complicated repair and should not be attempted buy untrained mechanic it can also be costly repair
Feb 16, 2009 | 2001 Triumph Legend TT
95 GMC Sierra 4L60E will not shift down to 1st or up to 4th.
no power stuck in 3rd gear electric shop unless youve burnt it up good luck...www.TransmissionGarage.com
Jan 28, 2009 | 1995 GMC Sierra
Shifting problem
sounds like it may be either a converter problem or u got some bad clutches in third in the case you need to go to a tranny shop.
Jan 27, 2009 | 1998 Honda Civic
98 Civic Auto Trans Slippage
you need to replace clutch pack for that gear can be ordered seperately from parts store or dealer if you want to save money call peach street auto recycling at 1800-365-2341 for a warrantied used one! also might be time for change trans filter and fluid filter could be slightly clogged but I lean towards clutch pack I replace these alot on Hondas
Dec 12, 2008 | 1998 Honda Civic
Garden Logo
186 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
