Question about Monster NCredible NTune On-Ear Headphones
My right speaker has no sound coming in the headphones they are monster n tune brand new
Right side speaker is not working brand new receive then today
How to change battery in nokia monster WH-930
There is no battery in this model headphone. Look for a broken wire. You'll need a continuity meter to test for open wires.
Jul 25, 2016 | Monster Nokia Purity HD WH-930 Headphones...
I've purchased some IR headphones to link with my Alpine in car DVD player. The sound is only coming through one side of the headphones?
Have you checked that both earphone speakers aactua Work? If they are not expensive ones, you may have bought a did set.
Dec 02, 2014 | Alpine Audio Players & Recorders
Cant get sound to play through speakers? proper way to hook up?
Do you mean HDMI from Monster, if you do ensure that the cable is connected securely to the correct port. HDMI cables rely on both the devices for sending and receiving. Nothing will happen until both devices send the opposite signal. Hope it works for you!
Apr 29, 2013 | Teac AG-V2050
I just bought a used jvc rx9010. it powers up but no sound from any speaker and shows headphone all the time what should a layperson check???
No speakers are selected if just headphone is displayed. Press the speaker button just under the power button. No station is tuned when auto muting is displayed. Hook up an antenna to the receiver or use a different source like a cd player.
Apr 07, 2013 | JVC RX-9010V Receiver
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Jan 20, 2013 | Yamaha RX-V540 Receiver
Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Nov 24, 2009 | Sennheiser RS 140 Consumer Headphones
Brand new. No sound from any speakers or headphone. Headphone indicator is on without headphone jack inserted
try to reinsert the head phone jack there is small switch in side while moving or play the system and try to insert
Nov 17, 2009 | Onkyo TX-SR876 Receiver
New headphones
Try plugging them into the jacks on the back of the PC case. Make sure you connect the right connector to the right jack. If this works, then there is a problem with the front jacks. Sometimes they are left unattached when the PC is assembled.
Also, check in control panel under sounds and make sure you have a sound scheme selected. If it says no sound scheme, select one, the click NO if Save sound scheme prompt comes up.
Apr 30, 2008 | Audio Players & Recorders
Sony cdx mp40 bus audio in
ok dont know if you will check up on this but fm transmitters are all garbage. for true undistorted sound go to an electronics store and ask for a rca to headphone cable. then just hook it up to the rca input and run the cable out of either the unit or somewhere on the dash. this will alow for a true connection and if you buy a brand name cable i.e. monster, radioshack, sony etc. should sound amazing. always happy to help.
big c
Dec 25, 2007 | Sony CDX-CA710X CD Player
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
Monster NCredible NTune On-Ear Headphones Logo
90 people viewed this question
Top Monster Audio Players & Recorders Experts
Lawrence Oravetz
Phillip Hicks
Phillip Hicks
Bill Boyd
Are you a Monster Audio Player and Recorder Expert? Answer questions, earn points and help others
