Question about ASUS M51 Computers & Internet
All lights up but will not start
My ne asus m51 desk top wont boot up windows 8 it clams i need a disc or some other external mida device to start it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
Hard drive working, or even present?
Posted on Jan 10, 2014
4 Suggested Answers
jeffreyhenry
  • 33 Answers
SOURCE: toshiba a205 laptop wont boot
This sounds like a file error (but not positive). My suggestion would be to change your boot order in bios ( a must since this is a Vista machine and CD-ROM is always set as one of the last. Hit F1 (or maybe F2?) when first turning it on to get the bios screen. Go to the Boot menu and set the CD-Rom as the first in order, then hit F-10 to exit and save. Be sure to put in your vista op system cd in your rom drive and see if you can't do a system recovery with it. I know that it was an option with XP.
Posted on Jan 20, 2009
HEMPYODA
  • 168 Answers
SOURCE: xp wont turned on it will not boot to the desk top it frezers
This should fix your problem. Even w/o your installation disk. I have used this program to fix Pc's I have picked up off the side of the road. I would hit the power button, it would show the BIOS then it would stop and shutdown. This fixed 99% of them I have picked up.
Go here
using a torrent program ie (utorrent, shareaza, etc) download SPINRITE.exe.
Burn this on a disk, the program is written with freedos included, but this will not work with 100% of laptops.
if the program stops and shows you a red screen with an error, use a program such as PowerISO to burn the disk and make it a bootable image by adding a .bif
after burning the program to disk-
  • insert disk and reboot
  • press any key to boot from cd if asked
  • when you see Prompt, change to your default cd drive.
  • type SPINRITE to start program
  • use recovery option 5
this may take a few hours or a few days depending on the condition of the HDD.
I have used this program to fix computers I've picked up on the side of the road. I would power it on, start to load then go into a loop. after running this program overnight I was able to reboot (after removing disk) and the pc started right up.
Make sure you run a program like Ccleaner (you can get at www.fileippo.com) to clean your registry2.gif and junk files after completion. ^_^
Posted on Sep 17, 2009
  • 2666 Answers
SOURCE: my asus eep pc 701
It looks like either the laptop HDD has failed or has become dislodged. Remove the HDD coverplate and ensure the HDD is correctly seated and secure it.
As to the ghosterr.txt problem the biggest cause is a dirty/scratched disc.
Posted on Jan 14, 2011
I have asus laptop. When I try to start it up it says 'reboot and select proper boot device or insert boot media in selected boot device and press any key'
The laptop can not find an operating system, Windows or some other system, which means that the operating system has been corrupted. If you made a recovery disc you will need to put it in the DVD and reboot. If you did not make a recovery disc or thumb drive you will need a disc with the operating system on it.
Aug 14, 2015 | ASUS Computers & Internet
I keep getting error code 0xc000000f on my asus laptop and don't have the start up disc
Solved] Fix Windows 8 Boot Error 0xc000000f go here for instructions http://www.smartpctricks.com/2013/09/solved-error-code-0xc000000f-windows-8-a-required-device-isnt-connected-or-cant-be-accessed.html
Sep 30, 2014 | ASUS Computers & Internet
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Error code oxc0000185
1. Have you made any changes to the computer prior to this issue?
2. What is the complete error message?
3. What is the make model of the computer?
Generally, this issue occurs if there is any corrupted file.
You may follow the below given methods and check if it fixes the issue.
If you are not able to boot to the desktop, you may perform Automatic repair from DVD and check if it helps.
Method1: I would suggest you to remove all the external devices connected to the computer (except mouse and keyboard) and perform an Automatic repair using Windows 8 bootable DVD or USB drive.
Follow these steps to perform Automatic repair
a) Insert the installation DVD or USB and boot Windows 8 from it.
b) In the 'Windows setup' page select the 'language to install', 'Time and currency format' and the 'keyboard or input method' and click on 'next'.
c) Click on 'Repair your computer' and select 'Troubleshoot'.
d) Click on 'Advanced options' and select 'Automatic Repair' and select the operating system.
Method2: I would recommend you to perform system restore from the disc and boot to the desktop
Perform system restore to previous working date.
a. Boot from the Windows 8 DVD.
b. Once you get the welcome screen of installation with the option "Install now"
c. Click on Repair your computer
d. On the next page click on Advanced Options
e. Select System Restore and check if you can start the computer.
System Restore disclaimer: When you use System Restore to restore the computer to a previous state, programs and updates that you installed are removed.
Hope this information will help you.
Mar 16, 2014 | Asus Systems Asus R503C-RH31...
My boot log must be set up incorrectly on my desk top
If you have boot to disc set higher than your primary hard drive you will typically see this. This is normal and in a few seconds it should boot to your hard drive as normal. If it isn't passing this point you can set hard drive to first boot device in BIOS. Also make sure you don't have any flash drives or external hard drives plugged in. Your computer could be trying to boot from them and it will just sit there.
Dec 24, 2012 | Computers & Internet
Asus eee pc 1015x
Hello
The answer is YES. You can load Win-7 from an external DVD player, after making it as first boot device. You must have get DVD as first boot devce and the internal hard disc to second boot device. Click out all boot devices to none, by entering into the bios window. You can get the bios settings, by press and hold the "Delete" key of your computer, as it first try to load. OK.
Jan 28, 2012 | ASUS Eee PC 1015PXPU17RD Netbook
My asus 1001ha is infected with viruses & wont do anything how do i restore to factory settings?
If it is a bad virus that won't let you do anything on the computer, follow the instructions on this link. If you can install programs on your computer, follow only steps 7 and 8 from the above link.
If you still want to restore it to factory settings, you will need the restoration CD/DVD that came with the laptop, put it in the drive and boot from it to start the restoration to factory settings. If you don't have the restoration disc, you will need a Windows installation disc to install a clean copy of Windows and wipe the HDD. Same process, put disc in and boot from it then follow the instructions for Windows installation (you will need the drivers disc though).
Dec 05, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My ps5800vm desk top computer wont go to sign in window on start up
Have you installed any new updates or software or drivers?
If so i would boot in safe mode by pressing F8 on boot up an remove the changes you have made.
If that does not solve your problem i would suggesting doing a system restore through booting in safe mode by pressing F8 at boot.
If that still does not work i would suggest a clean install by booting from your operating system cd.
Nov 04, 2010 | ASUS P5S800-VM Motherboard
Wont display the desk top
Try rebooting, tap F8 to get into the multi-boot options. Scroll down and choose "Last Known Good Configuration" windows should boot up normally. If you have made any hardware changes or if windows perfromed a corrupt update, that will require some additional help.
Jan 12, 2010 | ASUS Eee PC 701SD
I have an asus eeepc and the windows startup window keeps going over and over without going to the desk top
boot loops usually indicate 1 of 2 thinks
- a corrupt or damage operation system
or
-a bad hard drive
unfortunately, i know these netbooks don't have a disc drive, but if you have access to an external one, see if you can get your hands on a hardware testing program like drive fitness test. if that passes, you know your operating system needs to be reinstalled.
Jan 16, 2009 | ASUS Eee PC 900 16G Notebook
Computers & Internet Logo
97 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
