Question about Lamson HOME PRODUCTS AR180 "PLUG IN SLIDE" INCANDESCENT/HALOGEN DIMMERS
Apparent fixture problem for halogen plug
For recessed halogen fixture. Tried replacing blub but verified blub itself is fine. Blub has 2 prongs that plug into base attached to 2 wires. Should I try replacing this base? Thank you
  • 44 Answers
This dimmer was not made to dim a load smaller than 40VA. That halogen bulb would only have been 20VA or so.
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
I think that when your bulb burnt out, the dimmer over-volted the transformer and smoked it. That said, I think you have a fixture problem and, possibly, a switch problem, too.
Posted on May 30, 2009
Where do I get replacement halogen blub
Hi Sandie
You are asking about a Microwave oven...right?
They usually don't use halogen bulbs. Just a standard incandescent bulb. Don't need super bright in Microwave oven.
Take the bulb out and note the Voltage, Wattage and Shape & Size of the base. Bayonet or Screw etc. some details may be stamped on bulb.
Replacements can be had from many sources. Hardware / Electronics... depends where you are.
If the bulb is halogen for a vehicle headlight for example... take original or photo to an automotive shop.
Good Luck
Apr 07, 2015 | Microwave Ovens
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Nov 16, 2013 | Samsung HL-S5086W 50" HDTV
Removed the switch plate and connected the two wires going into the dimmer box and the lights still dont come on. I as thikning by bypassing the dimmer the lights should still function. What else could be...
I am going to stick my neck out a little with this one although I agree with BoomerP. The clue of halogen bulbs is feeding my answer. Halogen bulbs require a high voltage transformer to operate and won't normally work with a dimmer but I never tried it. Bypassing the switch should bring them on though. If you have the proper voltage at the switch and they don't work with the switch bypassed, its probably a bad transformer in the fixture. Good Luck. Be careful.
Feb 04, 2011 | Lutron ELECTRONICS MAW-600H-LA SMART...
I have a problem with my kitchen's recessed lighting. For some reason, the six bulbs will go out during the evening hours, then come back on. There is no pattern, with one, two, three or four of them out...
It sounds as if you may have higher wattage bulbs and/or the wrong type of bulb installed in the can fixtures than the recessed cans are rated for.
When the wattage of the bulbs is higher than the rating of the fixture, and/or the wrong bulbs are being used, the recessed can's thermal overload device will shut off the light, to prevent damage and a possible fire situation.
It is unlikely that you've got a faulty dimmer, since you state that not all of the lights go off at once, thus it can be narrowed down to each can and thus the thermal overload being the culprit.
I would suggest you look inside the recessed can light fixture and determine what the maximum wattage bulb you can use, (60, 75, 90 watts, etc.) and use the next lower wattage bulb instead. I also install only Halogen bulbs in recessed cans, (they have a flat lens vs. a rounded bulb lens area like PAR type bulbs). Halogen bulbs are also the most efficient incandesent bulb that provides the whitest light possible and directs more light (and thus heat) downward away from the recessed can.
I avoid using a standard light bulb or PAR type bulbs in any recessed can fixtures as they tend to heat up quite a bit and cause the thermal protection to trip frequently.
As a Master Electrician that has installed literally thousands of recessed fixtures and dimmers, I can say that my customers prefer the Halogen light over standard bulbs and they last longer too.
I hope you find this Very Helpful and best regards!
Sep 17, 2009 | Lutron Diva Dv-600P Light Control By
Glow plug indicator light
Hi, if the egnine start alright. then it will be the LED or just a blub need replacing.
Jul 21, 2009 | 2002 Ford SVT Focus
Change headlight blub
The whole head lamp assembly has to come out to replace the headlight bulb. Here's how to do it.
Here is a link to instructions
http://autorepair.about.com/library/a/1i/bl808i.htm
Jun 18, 2009 | 2002 Jeep Grand Cherokee
TV turns off/on
remove the bulb,(very easy to do just follow directions in the manual). On the top and bottom of the lamp there is a fine mesh screen. mine was plugged with dust. I used a vaccuum hose to remove the dirt, replaced the lamp and the tv now works.I found this remedy at a site but can't remember where (crs syndrome). saved me a $200 service call.
Jan 26, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Replacing a headlight
go to your parts store and purchase the new halegeon blub. READ very carefully the instructions on the box. DO NOT TOUCH the new blub lens.
Carefully pull and twist out the old blub and remove it from its base. Using the special material or a glove, install the new blub in the base, and then carefully insert it back into the headlight shell.
Bill
Nov 18, 2008 | 2004 Buick Rainier
Lamson  HOME PRODUCTS AR180 "PLUG IN SLIDE" INCANDESCENT/HALOGEN DIMMERS Logo
188 people viewed this question
Top Lamson Electrical Supplies Experts
Steve
Gene Haynes
Are you a Lamson Electrical Supply Expert? Answer questions, earn points and help others
