Question about Sewing Machines
How do i thread a toyota 7002 sewing machine - Sewing Machines
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
  • 139 Answers
SOURCE: How do I thread a Singer 6104 sewing machine
http://www.singerco.com/resources/threading.html Check out their threading diagrams, they are really helpful!
Posted on Apr 05, 2010
SOURCE: Sew Cute SC20 Mechanical Sewing Machine: how to thread sew cute machine ...
Place the origin bobbin thread so the thread is coming up (clockwise) extend to the thread tention, to the top thread holder, then down through the arm and then through the bottom thread holder, through the square thread guide above the needle, then through the needle, front to back. Check out a picture on ebay or amazon. That could help you visualize it.
If you are having trouble with the thread breaking, try changing the thread on the bobbins. The thread that comes with the machine is poor quality and jams & breaks. If you still have trouble, and might suspect the needle is dull or bent. Change it, it makes a difference. I had the thread problem with the machine right out of the box. Changed it and it works great!
Posted on May 22, 2010
My Toyota 444 sewing machine. When sewing,stitches ok on right side of material but underneath,stitches are entangled. sometimes it stops sewing and I have to pull thread out.
ALWAYS RAISE the presser foot when threading the top thread. (You will need to remove the top thread from the machine and rethread from the beginning.)
For tension, start out with it set about the mid-point on the tension dial. Then tweak it from there. If top thread is showing on the bottom of the fabric, tighten the top tension. If bobbin thread is showing on the top of the fabric, loosen the top tension. It's ideal when both threads meet in the middle of the fabric.
Sep 12, 2017 | Toyota Sewing Machines
My Toyota sewing machine was working perfectly well, but suddenly stopped, the machine appears to be jammed, What do you think the problem is?
Probably the thread is wrapped in the bobbin area. Remove the needle and try to remove the bobbin case. Otherwise, very carefully snip the thread nest and pull the threads out piece by piece. Don't yank!!!
Apr 22, 2017 | Toyota Sewing Machines
How to use a twin needle on my SR2000 toyota sewing machine
First, verify that your machine can use a twin needle. Most machines take will use a twin needle will have separate thread guides and duel thread spool pins.
To thread it, thread one thread all the way through one of the needles and then thread the second thread through to the second needle. This will help keep the threads from twisting.
Toyota RS2000 Instruction Manual
Aug 25, 2016 | Toyota Sewing Machines
How to fix a thread correctly on a Toyota sewing machine model 5500
You don't state what is the problem with the thread so we are unable to provide helpful suggestions.
As a starting point, make sure to install a brand new needle that is compatible with the thread & fabric you are sewing.
All About Needles
Second, always raise the presser foot while threading the upper thread.
Make sure the thread path is correct (consult the owner's manual), insure that no thread guides are skipped or the thread is not wrapped around something it shouldn't be.
Set the upper tension at the midway point between low & high numbers to test stitch. Tension is correct when both upper & bobbin threads meet in the middle of the fabric.
Understanding Thread Tension Threads
Apr 12, 2016 | Toyota Sewing Machines
My rs200 toyota sewing machine bobbin won,t take thread round to lift bobbin thread
At 8 months old must still be under warranty, so take it back before you have any more problems and get a replacement.
Jan 19, 2015 | Toyota Sewing Machines
The thread keeps coming off the take up lever on my Quilt 50 Toyota Quiltmaster while sewing.
take a piece of tape and put the tape of the take up lever or take a pair of pliers and close the take up lever just enough so the thread will not come off. I had the same thing happen on one of my sewing machines.
Nov 26, 2013 | Toyota Sewing Machines
Machine keeps sewing loopy under neath
change the needle
adjust the top thread tension one number or letter higher till the stitch
look better
rethread the machine top & bobbin
make sure to use every thread guide
make sure the thread has not come off the thread take up lever
Sep 01, 2012 | Toyota Sewing Machines
I have a Toyota RS2000 sewing machine. The thread has suddenly started breaking, and I am getting big bundles of thread under the fabric. What is wrong please?
try a top thread tension of 4
change to a new needle
clean under the needle plate & in bobbin area for lint or loose threads
also rethread machine top thread & bobbin just incase thread is catching somewhere
make sure the thread doesn't come off the thread take up lever
check to see if there are any burrs on the needle plate or the bobbin
Aug 10, 2011 | Toyota Sewing Machines
Top thread doesn't pick up the bobbin thread (Toyota sewing m.)
Hi! This may sound silly, but if you changed your needle and put it in backwards (which is easy to do), the top thread won't pick up the bottom thread. Take your needle out and check the flat side of the needle shank--which way is it facing? With a lot of the newer machines, the flat side goes to the back, but check your manual to make sure.
Let me know if this helps, ok?
Happy Sewing!
Robbie
Feb 12, 2010 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
