Question about Toshiba Satellite A35-S159 Notebook
"Toshiba Satellite A35 S159 PC Notebook turns off after running 10 to 29 minutes"
  • Chris Hingee
    Chris Hingee May 11, 2010
    You could have an over heating problem.
    Check the vents and fan for dust, clean the dust off the heatsink fins and fan.
Can't find hard drive on my toshiba satalite toshiba a35-s159
1) Make SURE you remove ALL power before removing the Harddrive.
Remove the AC adapter (Charger) and Battery.
2) http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-1.htm
Page 3
Go down to Steps 19 and 20. Click on the photos to enlarge,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-3.htm
[ The page numbers are in white at the Bottom, and Top of the pages.
Page1::Page2::Page3::Page4::Find another model ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 17, 2012 | Toshiba Satellite A35-S159 Notebook
My Toshiba Satelite a35-s159 can not connect to the internet unless its plugged into the wireless router or the modem
I had the same issue with the one I had. It was kind of a problem getting the WIFI to turn on. Consult your user manual or a quick google search to get the directions on how to turn on your WIFI. I don't remember if it has a switch on the front or not.
May 03, 2011 | Toshiba Satellite A35-S159 Notebook
I am replacing my Toshiba Satellite A35-S159 hard drive with a scorpio blue. the new HD is installed. when i turn on the laptop i get a flashing message. "pxe-e61 : media test failure, check cable pxe-m0f:...
In the BIOS, look in the boot options and take the "other devices" or "other" out of the boot sequence. Also check to see if boot from LAN is enabled. If it is, disable it. PXE is a protocol that will enable you to boot from a network drive or server. When it says that it failed, it is because it could not find an OS on the network
Jan 17, 2010 | Toshiba Satellite A35-S159 Notebook
A35-s159 laptop shuts down suddenly
Sounds like its overheating.Make sure the fans aren't covered up or it has enough clearance for airflow.
Oct 06, 2009 | Toshiba Satellite A35-S159 Notebook
I need to install drivers for a35-s159.The Toshiba support page no longer supports this model.I need the modem and Ethernet drivers according to my hardware mngr
Wow, I can't believe they removed it from their support page. bummer.
You can try a simple Windows Update.
It should detect the missing drivers.
Let me know if it doesn't.
Jun 15, 2009 | Toshiba Satellite A35-S159 Notebook
TOSHIBA
You can purchase it here. Click on system boards to view the boards available for your model.
Thanks and please take a moment to rate as fixya.
Dec 05, 2008 | Toshiba Satellite A35-S159 Notebook
A35-S159 TOSHIBA satellite
Toshiba no longer supports the A35-S159 laptop.I found my drivers here free! http://www.gzrcw.net/drivers/toshiba/Satellite/drivers_1176.html
Sep 26, 2008 | Toshiba Satellite A35-S159 Notebook
Lcd toshiba A35-s159
your correct the lcd inverter or the lappy lcd bulb is shot
ebay toshiba satellite a35 lcd inverter buy that link me
bakerandre2000@yahoo.com i walk you you need a screw driver
Apr 12, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite A35-S159 Notebook Logo
201 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
