Question about GE GTS22WCP Top Freezer Refrigerator
Not cold enough ice
The ice maker does not make enough ice.
  • 100 Answers
SOURCE: Fan is Running
Your refrigerator isn't defrosting. When you melted the ice on the coils in the freezer you might have noticed a glass tube with a wire going into each end this is your defrost element that is probably bad. If it tests out good then your problem is either in the defrost thermostat, or the motherboard that tells your fridge when to defrost.
Posted on Nov 15, 2007
TheMobilian
  • 8220 Answers
SOURCE: frost in back of frost free freezer, ice maker not
Whats happening is the defrost heater has failed. It is causing ice to build in the freezer and that is stopping ice production and fresh food chilling. Solution: Remove panel to evaporator and replace heater. Use hair dryer to melt ice. I have your repair manual: HERE
An air conditioning heating and ventilation expert named Dr Z normally makes HVAC videos but his neighbor's ice box did the same as yours and he had a chance to check it out and made this short film.He calls it his HVAC Refrigerator repair I thought it was pretty cool, cause it gives a good idea what is involved in this repair. HERE
Posted on Feb 07, 2010
  • 152 Answers
SOURCE: Freezer does not get cold enough to freeze so ice
Check for frost on back wall of freezer if there is frost you have a defrost problem
Posted on Feb 18, 2010
  • 1891 Answers
SOURCE: freezer frosting up at ice maker base, and fridge
if freezer side is frosting up / the defrost system is or has failed . there should be no frost in a no frost frig . being a G E either the radiant heater has failed of the defrost p c board is out . most common and least costly is the heater .. hopt this helped mm
Posted on Apr 19, 2010
caroldon
  • 17129 Answers
SOURCE: Fridge and freezer doesnt seem cold enough. Things
Please check the timer the thermostat and the heater for the auto defrosting to work. Switch off the fridge and after all the frost has gone off switch on to see if the sooling returns . If so you can be sure that the timerr does not work and so reduces cooling on frosting. If there is still no cooling then you will need to check onthe compressor and the gas pressure. Get help to confirm and take an estimate before attempting, get an warranty assurance for work. Hope you try out and see first.Good day
Posted on Aug 10, 2010
Ice maker is not functioning. no ice being made.
There are a few basic things you need to make ice. First is a refrigerator that is cold enough. Most ice makers in refrigerators need 15 degrees or colder in the compartment that the ice maker is located. Second, a functioning water valve and ice maker. What model of refrigerator do you have?
Mar 24, 2016 | Refrigerators
Ice maker makes very little to no ice.
If the freezer temp isn't cold enough it won't make ice if you can check temp it should be close to 0deg f. . if you don't have a temp guage us you ice cream hard it probably cold enough. The frigidaire ice makers fail often
Oct 19, 2015 | Frigidaire Refrigerators
My maytag fridge model# mff2558veb4 ice maker is not making ice
Is temperature cold enough in the freezer .if it is cold enough can be water valve or ice maker unit
Mar 08, 2015 | Maytag Refrigerators
Samusung RFG297HDRS Ice maker not cold enough to produce ice.
Suspect that the rubber boot that runs all around the edge of your freezer door is deformed, allowing warm air to seep into your freezer. You will see where your temp sensor is located by clicking into the site of a parts supplier like ShopJimmy.com and pulling up their photo of the guts of your unit.
Oct 29, 2014 | Samsung RFG297HDRS Stainless Steel
Why won't by ice maker make ice?
The icemaker will not harvest if the temperature isn't cold enough. this may be why you are not getting ice.
Oct 04, 2014 | Frigidaire FRS6R4E Side by Side...
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Water to ice maker leaking in freezer
I emptied out my freezer. Turned it off and made sure it was dry and clean. Then I turned it back on, but left the metal wire that controls the ice maker up so water wouldn't fill until freezer was cold enough. When cold enough, I dropped the metal wire down and kept a close watch of the filling process. Everything went smoothly. No problems in this first 24 hours. I think ice must have built up and letting it thaw and dry made the difference.
Oct 20, 2009 | Amana Refrigerators
GE Profile Artica icemaker does not make ice. model # PSC235GNA. We still get cold water .
use a thermometer make sure freezer is normal operating temp if freezer is cold enough and water is filling ice maker you may have bad ice maker very simple system make sure your getting water 1st thing to check is for water if you have water and freezer is cold youll have ice
Aug 18, 2009 | GE Refrigerators
I have an il gelato ice cream maker and it does not get cold enough ,what can I do if anything.Jack It cools down but it will not get cold enough to make ice cream. it appears that the compressor works but...
Unfortunatel for what it will cost to repair you can buy another on ebay for way less, i know thats not what you wanted to hear but its the simple economics of our high priced repair world. Happy hunting S/B around 40.00 plus shipping
Apr 22, 2009 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Installed replacement Icemaker but will not dump new ice...
Either your freezer is not cold enough or you got a defective ice maker. It needs to be 15 degrees or colder to make ice. The water may be frooze but not cold enough to close the internal thermostat inside the ice maker. If your freezer is colder that 15 degrees, take the ice maker back to Sears, you got a lemon. Good luck!, Mack
Jan 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE GTS22WCP Top Freezer Refrigerator Logo
20 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
