Question about Gateway 310S (2900621) PC Desktop
Video card upgrade
The gateway 310 series has an intergrated video card. I was wondering if I can upgrade it. Does the 310 series have an agp slot for video upgrade or can I use the pci slot If video upgrade is available. Lastly. What video card upgrade would you recommend.
    Scholar:
  • 51 Answers
Relevant link
Yes it does have an AGP slot, which you can confirm easily by looking at the motherboard. The AGP slot would be found at the top of the available slots and is brownish in color and slight smaller than the several white PCI slots.
As for what card to put in, that depends on your budget and needs.
If you're a gamer, spend as much as you can and go with a N-Vidia based AGP card.
Please rate this as solved once you've read it, unless you have further questions, then post another comment.
Thanks!
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating other than Solved
Posted on Oct 18, 2007
What upgrade video cards are recommended for gateway gt5658e?
If you system is old enough to have an AGP slot in it, you need to buy a new PC. It is very likely your system is so old that AMD stopped provided support for the intergrate graphics and the blue tint is a result of the last time you upgraded the drivers. You can either install legacy drivers and hope for the best, or just buy an updated PC.
Aug 25, 2014 | Gateway Computers & Internet
I need a recommendation for a video card that will work in a Gateway Performance 733 that originally came with integrated graphics.
That is a pretty old PC to be upgrading, but a new video card might help a bit for video viewing.
Im assuming that it has either only PCI or maybe a 1st gen AGP slot. You would need to open it and find out. Iff all the slots look exactly the same its PCI if the top one is different or even darker brown in color its AGP. now dont get the regualr PCI mixed up with PCI-E (pci-express16x) those will not fix and they are what is mainstream right now in the video card market.
I'd suggest looking on eBay or other online retailers to find a PCI oe AGP card.
Apr 17, 2009 | Computers & Internet
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
Gateway E-2000 series wimpy video needs upgrade
according to the manual it also has an AGP slot so you could start there.
http://downloadmirror.intel.com/15328/eng/D845GRG_D845GBV_ProductGuide_English.pdf
That is the manual for the board you listed and has the spec for the AGP slot etc.
Hope its of help.
Bob
Jul 16, 2010 | Gateway E-2000 PC Desktop
I want to upgrade to a new video card
You can put new Video card accordingly. Just buy an good Video card which have inbuilt memory and that support your operating system. There are loads of Video card available in the market.
Dec 26, 2008 | Gateway GX7018E PC Desktop
Graphic card for compaq 8ooo series
I'm assuming it's a Compaq Presario 8000. The 8000 series has several sub-models such as the 8000T, 8000A, etc. The 8000A has several sub-sub-models.
The 8000T has an 8x AGP slot so you will be limited to either a PCI or AGP 8x video card.
You haven't stated your budget or what kind of games you play (solitaire or Word of Warcraft, etc...).
This card is the top rated AGP video card on NewEgg:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102730
Nov 22, 2008 | Computers & Internet
AGP Video slot
the DDR doesn't matter.
your motherboard has a AGP x8 port, most if not all cards for agp will work!
buy a AGP x8 card. - I have no idea what you mean with series 1 or 2, that has never come up within the 10 years I've worked with computers.
You can learn about the AGP port here
http://en.wikipedia.org/wiki/Accelerated_Graphics_Port
May 30, 2008 | Acer Aspire T310 PC Desktop
Video card for the gateway 507gr
Yes, your computer specifically supports:
PCI Express 16x and
PCI Express 1x
The 16x is the long one and the 1x is the reallly short one. Most likely the card that you get will fit the big slot. Be careful not to upgrade too high though, because if you do you may have to upgrade your power supply as well. Ask someone at gateway or a local shop for a recommended card for your system.
Apr 23, 2008 | Gateway 507GR PC Desktop
ATI 9600 xt problems
Hi, Im guessing that your motherboard has an intergrated video card & you installed the 9600 card into the opened AGP slot on the board. If you would have listed the model number of your motherboard I would't have to guess. What you need to do is enter your bios & make a change so your bios loads the AGP slot & not the intergrated video card. How to get into your bios? As soon as you turn on the Pc press the Delete key every two seconds. If your system fails to load the bios than you will need to try some of the others F keys. Let the PC finish loading. Re-start the PC. As it starts up try the F1 key every two seconds. Continue in this manner using these other F keys untill your system boots into the bios. F2, F10 or F12. One will work for you. Once in the bios use your manual if you have one. You are looking for Video display. You want the bios to load the AGP slot first, this will disable the intergrated video automatically. Your Pc will now see your 9600 video card & you will be able to load it's software. If the 9600 uses ATI's software you should update the Radeon software by going to ATI/AMD & update your video software with the latest drivers. Click the link I have posted below to upgrade your Radeon 9600XT card. Good idea to save the link.
http://ati.amd.com/support/driver.html
Fill in the needed information to get to your driver software.
If your using Win XP Pro or Home click here:
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
Feb 19, 2008 | ASUS RADEON 9600XT, (128 MB) AGP Graphic...
GeForce2 MX400
The geforce2 mx400 is an agp video card. If you want to stick to the same agp slot you don't have many options these days and the prices are very similar to PCIE slots except the PCIE is a newer technology that would provide a lot better performance.
If you can afford it you should upgrade your motherboard to one that support PCIE and then get a good PCIE video card. The best price/performance these days are the 8600GT cards so look into that. The money you save buying a new video card may even contribute significantly to a new motherboard plus you get other benefits with a newer mobo ie. faster ram, SATA technology more usb ports and support for more CPUs.
Just becareful on what CPU you are using at the moment and make sure the new motherboard supports your cpu.
alternatively look for a used agp slot graphics card ie. the ati 9800pro or nvidia 6xxx series is a good choice of a slight upgrade from where you are.
good luck
smeags.
Jan 08, 2008 | Gateway GeForce2 MX400, (64 MB) AGP...
Gateway 310S (2900621) PC Desktop Logo
408 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
