Question about 88sears.com
88 sears wfm - 88sears.com
How to take ignition lock off 88 mazda b2200 , the lock wont come off the column?
These ignition / lock cylinders use sear bolts , When you put the new one on an tighten the bolts the heads sear off . To get old one off take a chisel an hammer an hit the old bolt on the side an get to loosen ! Hope I explained this well enough . There is a video on you tube I saw on how to do it .
Jul 23, 2016 | Mazda Cars & Trucks
How to operate a Bosch WFM 2000 washing machine
Anon, could not find WFM 2000, go to the link below or Google search your make and model# manual.
Download instruction manuals
Apr 29, 2016 | Bosch Washing Machines
How to figure square inches
Imagine you have a stack of pieces of paper or cloth that are one inch square, or 1" X 1".
Then, whatever you wish to convert, just multiple the length times the width.
For example, a piece of paper 8" X 11".
8 X 11 = 88.
Hence, you have 88 square inches of paper.
Mar 15, 2016 | Kenmore Vintage Sewing Craft Quilting...
Realistic 2004 low audio on vhf brodcast band
Hi Did you get the answer to the low volume on wfm as i have the same problem
Jan 27, 2012 | Radio Communications
95 oldsmobile 88 royale gas tank removal
There are two bolts that hold the two tank straps,
as on almost all fuel tanks
Your problem will be rust,as far as getting the bolts out
Sometimes you have to drill one out & get a new one
at the dealer or sears hardware, etc
Have you started the job & have a question?
Jun 30, 2011 | 1995 Oldsmobile 88
Winchester model 88. with the trigger assembly
Less Than Perfect
The Model 88 had its faults. The trigger moves with the lever and the resulting linkage to the sear results in a rather spongy, creepy trigger break. If you want to see your gunsmith turn pale, waltz into the shop with an M88 and ask for a crisp three-pound trigger.
If you already have taken the gun apart, don't be afraid to hone the parts on a stone , keep them flat, you don't want anything rounded off. Especially the sear. I found that quote up top from a winchester sight,
Feb 22, 2010 | Optics
Difficult belt replacement on 1997 Olds 88
the motor mount needs to be removed to replace the belt. so, if you've never removed a motor mount, I would let them handle this.
Dec 30, 2009 | 1997 Oldsmobile 88
Can't seem to get the correct size belt for my mower deck
The belt called for this tractor is 532 14 42-00 the belt is 1/2" wide 3/8" thick and 88 3/8" long
Nov 08, 2017 | Craftsman Garden
88sears.com Logo
89 people viewed this question
Top 88sears.com Computers & Internet Experts
David Payne
David Payne
Are you a 88sears.com Computer and Internet Expert? Answer questions, earn points and help others
