Question about Bernina Sewing Machines
Bernina, Needle is off-center
Bernina needle off-center I have an older Bernina 1000 and the needle is off-center. When facing towards the machine the central needle position is farther to the right than it should be. If the needle is repositioned to the extreme right, it will then strike the plate. The needle positioning knob seems slightly off too. In the center position it seems to be stopping a slight bit more to the counter-clockwise position than it should be. There seems to be a little odd "springiness" to the dial when it is put to the extreme right. The left position seems to lock the dial in place relatively normally-or a least it seems that way. I'm not working these days, so I would appreciate any suggestions that would help me repair this myself rather than going to the shop. Thank you for your help! Jen
  • jenshop1 May 17, 2009
    Okay...after fighting with this for a couple of days, I figured out the problem about 20 minutes after making the post–of course!  So for the benefit of future readers:  The problem was the needle.  Not sure how I managed to make this mistake twice, but this is the story:  My first act (yesterday) was to replace the needle in case it was bent (didn't look it).  The new needle had the same problem-horizontally misaligned.  After doing more research today about how the bobbin assembly functions, I observed that the needle was hitting the bobbin case when fully descended.  Weird.  Turns out that the needle was not fully inserted into its socket (or whatever that thing is called).  Maybe I didn't tighten the screw enough when replacing the needle; I'll have to watch it.  Anyway, I took the new needle out, then replaced it, paying careful attention that it was full inserted and the locking screw was fairly tight. Miraculously, the needle was then perfectly aligned.  Sews fine; no skipped stitches.
    Lessons for me:  1) Check every detail, don't assume anything.  2) The needle doesn't travel perfectly straight necessarily, but the important thing is its position when it reaches the bobbin.  (This is what clued into a problem with the needle's *length*.  3) Double check.
    Hope that this helps someone else out...!
    Jen
    Solved.  Please see my follow up comment.  This solution may work for machines other than Bernina that have a similar needle assembly.
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
RickE1
  • 202 Answers
SOURCE: My machine Bernina 830 does not run.
Rose, most likely your machine is gummed up and needs oiling. A product called Tri-Flow is best. It can be purchased at most any hardware store. Or just use normal sewing machine oil. Open the top and put a fair amount of oil down behind the knobs and let it soak in. As it soaks just wiggle the knobs or turn them little by little back and forth until they free up. Don't force anything as something will break.
Good luck
Posted on Nov 29, 2008
candleliteva
SOURCE: Bernina 1630
I have a Bernina Virtuosa so not the same machine - but this may help. There is an icon on the front of the machine - it is a needlepoint pointing at a dot in an oval - there are arrow buttons on either side. These move the needle left or right of center and it shows on LED screen. I checked mine just now and if you turn machine off and on it resets to center automatically. Hope this helps - Happy Sewing!!
Posted on Dec 15, 2008
SOURCE: the needle hits the bottom
Actually, first make sure you have the needle in properly... take it out, then replace it taking special care to hold it straight up and down. If that doesn't work, then the screws on your plate may be loose or one is missing, so manually shift the plate back to where it needs to be and tighten screws.
Posted on Dec 17, 2008
  • 9 Answers
SOURCE: Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Posted on Feb 21, 2009
I have a Bernina Patchwork 140. How do I change the needle to stop in the down position? The sewing manual is no help.
As far as I know, the Patchwork 140 doesn't have a needle stop up/down button. You'll need to use the hand wheel to bring the needle up or down, as needed. The Bernina machines that have a needle stop up/down button have this button below the LCD screen. (On those machines, it's usually the left-most button below the LCD.) I suspect the index giving a page number for the Needle Stop Up/Down button is a artifact of using the same index for multiple machines.
The manual for the Patchwork 140 is available at Manuals Lib here: https://www.manualslib.com/manual/1002243/Bernina-Activa-131.html . The Bernina 135 has the needle stop up/down button. See https://www.bernina.com/en-US/Support-US/Machines/BERNINA-activa/BERNINA-activa-135 . The manual for this model is https://www.bernina.com/getdoc/90f75840-2b12-4f46-88f2-76f09e35d8d4/030529-52-04_0303_a135-a145_EN .
I hope this helps.
Jul 31, 2017 | Bernina Sewing Machines
I have an 820. The needle threader is clean of lint but still does not work
Threading the BERNINA 880e 830e 820 Bernina Sewing Center Tampa
http://www.manualslib.com/manual/726261/Bernina-820.html?page=30
Bernina 830 880 Needle Threader Cleaning
Install a brand new needle. Verify that it is installed correctly and is facing straight forward. If it is still not threading properly, then something may be bent or out of place in the threader.
May 15, 2016 | Bernina Sewing Machines
How to thread the Nelco A2?
To find a user's manual, search the internet for:
Manufacturer + Model + the word "Manual"
Search YouTube videos for threading tutorials:
Nelco Zigzag Sewing Machine Final Test Demonstration Video
VINTAGE ALL METAL NELCO MODEL 400 2 SEWING MACHINE
NIFTYTHRIFTYGIRL Vintage Nelco model 250 sewing machine
With your Nelco, be sure that you install the needle properly. Frequently, Nelco machines take the needle with the flat side facing toward the throat of the machine--not toward the read like most other machines. The upper thread will thread through the needle's eye from the left toward the right. They also are a left needle position machine--meaning, the standard position of the needle when sewing straight stitch is at the left side of the presser foot, not center like most other machines.
Nov 15, 2015 | Sewing Machines
How do I keep the walking foot from unscrewing the needle holder on my bernina record 730
I don't know about bernina but I will take a shot at your problem. Make sure your needle is inserted in the needle arm with the flat part of the needle facing away from you. After it is for sure inserted in the crack in the arm tighten the needle down firmly. If the needle is backwards it will continue to come out. Your machine might sew but it will possibly make noise when the needle is in the down position. The problem isn't the walking foot.
May 22, 2014 | Sewing Machines
Why wont the needle go up and down?
what model machine? First check that the bobbin winder is not engaged or the wheel on the inside of the handwheel is tightened, by turning towards the back of the machine. Often times on older Berninas the basting mechanism gets gummed up and has to be completely disassembled and polished/oiled as the replacement part is not available.
May 01, 2014 | Bernina Sewing Machines
Can Bernina walking foot with soles and seam guided used on Activa 210 be used on 16 yr old Bernina Activa 230????
Please be advised that the newer machines (Classic models) such as the 130-180 and up, have a totally different geometry. This is to say that the older machines have a shorter distance from the center of the presser bar to the needle center. The newer machine design was increased to provide space for needle threaders etc. Older machines will use an older Walking foot model (still available).
Feb 27, 2014 | Bernina Activa 130
Machine is threaded but the needle will not pick up the bobbin thread. How do I fix on my bernina 65 machine?
Make sure the needle is not bent and is threaded from the front to the back.
The needle should be installed with the flat side of the needle shaft facing the back of the sewing machine.
Lower & raise the threaded needle, holding onto the end of the thread.
Then begin to sew.
If this does not help, then it may be the timing needs to be adjusted and this has to be done by a Bernina repair tech.
Apr 20, 2010 | Bernina Bernette 75
My needle wont pick up the bobbin thread
Hi. The most likely cause is that your needle is inserted backwards. There is a flat side on the shank of the needle and this flat side has to go in facing a specific direction (usually away from you, toward the rear of the machine) so that the needle can form a loop with the top thread to pick up the bottom thread. Some machines, especially older ones, require that the flat side be inserted facing right, or facing left (I have one of each), but in my experience most modern machines need the flat side of the needle shank facing away from you.
Sometimes, if the needle is in correctly for your machine (check your manual to be certain) and still isn't picking up the bobbin thread, the needle could be bent.
Check these out, and let me know if they solve your problem, ok?
Happy Sewing!
Robbie
Mar 03, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Bernina 1630
Dec 15, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
152 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
