Question about Infinity IL 60 Speaker
Sub woofer fails - Infinity IL 60 Speaker
What is a sub woofer pre-out ?
Sub-Woofer pre out is for connecting that terminal to the input terminal of any sub-woofer. The sub woofer which it should be connected must be an active type [that is, there must be independent amplifier section built it with that sub-woofer; not mearly a crossover network].
Oct 22, 2012 | Denon RC-920
How many total watts
Hello
The power rating for this amp is as follows.
Two channel: Sub woofer: Min 35Watts
Two channel: Other than sub woofer : 70Watts
One channel: sub woofer; 100Watts
One channel: other than sub woofer: 200Watts.
OK.
Dec 17, 2011 | Pioneer GM-X332 Car Audio Amplifier
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Sep 22, 2007 | Kenwood VR-507 Receiver
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
Infinity IL 60 Speaker Logo
26 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
