Question about Barska Optics Optics
How to install battery in Barska 1-4x28 IR Swat AP
Where is battery placed and what is needed to install battery
Barska Excavator 8-32x50 scope. Where is the battery? I assume within the turret to turn on the light and for adjusting brightness? How is the battery cover removed?
  • This scope does not use batteries. It uses an IR or Illuminated Reciprocation. The light available is guided through a light track and illuminates the dot. The setting adjustment is used to allow less or more light through to illuminate.
Regards, Tony
May 02, 2011 | Barska Optics Barska Riflescope Excavator...
This knob is not cumin off te scope what do i doooooooooooo
With a electric hair dryer, try warming up the cap. This should cause it to swell just enough to allow less tension on the threads for you to remove the cap counter-clockwise.
Mar 13, 2011 | Barska Optics Barska 10-40x50 Ir Swat...
How do I adjust the magnification for my Barska 4x28 electro sight rifle scope?
in a word you cant,,,,,its a 4x28mm so its a fixed scope at 4x's mag with a 28mm lens
Nov 27, 2010 | Barska Optics BARSKA 4x28 Electro Sight IR...
How do I use the range finding graph reticle from barska?
The IR Rangefinding Reticle is based on the military reticle that ranges tanks, believe it or not, front to back--whatever line the tank fits between will give the range to it...but the reticle has been adapted for use in some riflescopes. Trying to define the math behind rangefinding and downrange zeroing with multi-stadia reticles is complicated and takes some study to fully grasp the concepts, which is why I have a constantly available on-line article, entitled, "Tactical Ballistic and Ranging Reticle Analysis," right here--
http://specialtypistols.infopop.cc/Reticle_Ranging___App.pdf
Jan 27, 2010 | Barska Optics Barska® 8 - 32x50 mm IR...
How do yoyu change the battery on the reticle
Most models, the battery is located within the knob switch that illuminates the reticle, and can be accessed by removing the screw cap/insert of that knob.
Good luck
Feb 21, 2009 | Barska Optics Barska 10-40x50 Ir Swat...
No battery for simmons scope model no. 1057
This scope will use a 1.5 volt button battery that is 4.2 mm thick and from 11 to 16 mm wide. A thin rubber washer can be used with a V386 battery or a LR43. Both are 11.6 mm by 4.2. My scope came with a thin 16x12 mm ring made of plastic so that the battery would be held firmly into the center position.
After a close inspection, it is possible that a similar sized battery that is 3.6mm thick/thin might work also, but would have a shorter life due to less capacity.
I hope this is helpful. If not, I would be happy for you to sell me your scope for another gun of mine! :-)
carwhisperer1450@gmail.com
Dec 20, 2008 | Barska Optics Barska 10-40x50 Ir Swat...
Just bought used 8x32 swat not sure how to use it. are the win and elev numbers for shooting or just for siteing in rifle
They are for sighting in the rifle only.I know on TV the shooter reaches up and turns a knob.BOGUS! after sighting in the rifle, always replace the little caps because the scope is not sealed unless the caps are on.without the caps, moisture can penetrate the scope and fog the lenses.Good Luck
Dec 08, 2008 | Barska Optics Barska 10-40x50 Ir Swat...
Recoil from 300WSM
Well, it Barska says it's .50 cal proofed, whatever that means. One would presume it could take 30 magnum recoil then.
On the other hand, Barska is a low end quality manufacturer. You cannot expect durability in a low end scope. Of course, you could get lucky.
Unless you're target shooting at an immovable object, 10x - 40x is much more power than you'll ever be able to use. You're much, much better off considering a 4x - 16, for instance, in a higher end scope line than this scope.
Consider that at 40x the exit pupil would only be 1.25 which would make even the highest quality scopes quite dim. Barska won't have be best glass in the world and so would probably be unusable beyond some level like 18x unless in very favorable conditions anyway.
The problem with heavy recoilers and scopes is that the heavier the scope the more likely it is to take damage due to recoil. It's because it hangs out there on those high scope rings, and is heavy.
Nov 06, 2008 | Barska Optics Barska 10-40x50 Ir Swat...
8x32 swat scope
It's not a high end scope. Most times you're better off buying a lower power scope of better quality and you'll still be able to see more clearly than with a higher power yet lower quality scope.
Consider that 6x, and lower power, scopes were pretty much standard for WWII snipers, and that fixed 10x is still an accepted power level for snipers these days.
Nov 04, 2008 | Barska Optics Barska 10-40x50 Ir Swat...
Optics Logo
49 people viewed this question
Top Barska Optics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
xalint1
xalint1
Vladimir Frolov
Are you a Barska Optics Optic Expert? Answer questions, earn points and help others
