Question about Ruud UAKA030 Air Conditioner
Inside the house I hear a loud squealing sound whenever the air conditioner comes on. It is still cooling just fine. It is a Rudd, about 10 yrs old.
  • 148 Answers
Alot of times that noise is coming from the orifice in the air handler it is the gas flowing through the screen could have pick up something in the lines
Posted on May 17, 2009
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
Rudd air conditioner isn't cooling,blowing ,but isn't cooling my house because air is not cold
Hello, first check if the outside unit is running, if it is then check filter to make sure it is clean and that the blower wheel is clean and not dirty. If the unit is clean then most likely you have a low refrigerant charge due to a leak and will need a hvac tech to come out and fix the leak.
Jun 19, 2011 | Ruud UAMB Air Conditioner
Goodman central air conditioner not blowing normally
It sounds like the compressor is not coming on in the outside unit. If it worked fine and was cooling before, then your compressor probably over-heated and tripped the internal overload switch which causes it to stay off while everything else is working. The most common cause of your compressor over heating is an incorrect refrigerant charge, though it could be a few other things like a restriction in the copper line set. You will be able to hear the fan motor and the compressor kick on if you listen close while the system first turns on. If the compressor is over-heated, then after it cools to a save temperature, it will come on again, but only till it over-heats again. I would have the charge checked on the system, but remember that if the compressor is over-heated when the technician gets there, there is nothing he can do until it cools down and time is money! It's best to not run it until the problem gets figured out. Hope this helps and points you in the right direction. Good luck!
Jul 17, 2010 | Heating & Cooling
Rudd Heat pump shuts down. Compressor is on and goes out on
Is your condensor coil clean?Needs air to breath.
Feb 12, 2010 | Ruud UBHC Air Conditioner
Carrier Air V unit with loud noise
If it sounds like a scraping noise it could be the motor bracket ah broken and the squirrel cage (fan assembly) is hitting the fan housing, if it is more of a squeal than it very well could be a bearing. Very hard to guess without seeing or hearing it.
Nov 02, 2009 | Carrier Heating & Cooling
Loud screeching noise coming from the unit.
A screeching or squealing noise usually comes from the fan motor. There may be an oil port and you can buy a small telescoping oil bottle at a super hardware store or an a/c supply house. Before putting in he oil, remember to TURN OFF THE POWER TO THE UNIT and only use a light squeeze on the bottle - over oiling will cause a mess inside the motor. It may be a sealed motor and no oil ports. In either case, budget for a new motor as if it's to the squealing stage, the bearings are already damaged and it's a just matter of time before before the motor bearings fail. If possible, get oil on the bearings ASAP - and use the proper lightweight oil for made for this application.
May 05, 2009 | Amcor PLM16000 Portable Air Conditioner
GE Heat/Cool model AJHS10DCBM1
OK I will be looking over the manual. Now that squeal sounds like the squirrel cage fan scraping the housing around it. Those units are so tight fit they can be twisted one way or tightened a little to much they scrape. I love them for there silence win they work right but hate them because my hand are too big to move things around inside them. Stay in touch I will be looking around while
multi-tasking today- I'll be here!
Feb 02, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Air conditioning unit not cooling
the problem sounds like a defective capacitor its located on the condensing unit outside, also a contactor that is used can be defective also.
Jun 05, 2008 | Carrier 38CKC036 Air Conditioner
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
Ruud UAKA030 Air Conditioner Logo
275 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
