Simpson washing machine eziset 950 wont start says e91
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
hattonhall
  • 349 Answers
SOURCE: simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Posted on Oct 25, 2009
Testimonial: "i will try it thanks "
  • 159 Answers
SOURCE: simpson eziset 950 wont turn on
Hi there.There is a fuse inside the head panel.the fuse is a glass type about 3.5 amp.you can normally get these from an electronics shop such as **** smith or Tandy Electronics.Make sure the plug is out.the fuse is in the green circuit board.
Posted on Jun 01, 2010
  • 59 Answers
SOURCE: my simpson eziset 950 washing machine is leaking
OK the trasnsinssion will be full of water and the contents are being forced past the lower oil seal during agitation. You might enwuire about a new transmission or get a new machine....not the best news but if you went for a stronger make you could own it for twenty years......no joke. www.thewashingmachineman.webs.com ask tony
Posted on Sep 07, 2010
caroldon
  • 17130 Answers
SOURCE: Simpson Eziset 750 washing machine - rinse light
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Posted on Jun 20, 2011
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
My Simpson eziset 950 keeps coming up with error HC.
No water flowing in to machine. Check taps are fully open & filters on end of hoses are clean & not blocked. If all good then you probably have a faulty inlet valve.
Dec 14, 2015 | Simpson Washing Machines
Where is the lint filter on a Simpson Eziset 950 top loader washer?
lint filters for simpons top loader is at the bottom of the center lift out piece in the agitator
just pull the lot up and the lint filter is a small pocket at the end of it
Dec 10, 2015 | Simpson Washing Machines
Eziset 950 wont spin and gives slight electric shock
Possible that the motor has failed and it has developed a leak to the body which seems to be felt over the machine, Isolate the motor and test the external voltage presence.. if absent it can be related to the motor.
Jan 12, 2013 | Simpson Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Hi I have a simpson eziset 605 washing machine and it has stopped spinning.. I have checked the belt and thats seems fine the washing machine just wont spin.. if anyone has any idea of what it could be...
Hi Carlee just read your posting.Now the Simpson Eziset machines come in top and front loader versions.Which type is yours?Please reply with this additional information and I will help you rectify this fault.
Oct 03, 2010 | Washing Machines
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
Aug 28, 2010 | Washing Machines
Simpson eziset 950 wont turn on''
May 31, 2010 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
