Question about Garden
It is fully charged but will not work - Garden
Pedego hub motor jumped and then no power. Fully charged battery and have lights showing fully charged battery.
Please give us a call so we can fix the issue! (800) 646-8604
Thank you,
Pedego Team
Oct 01, 2012 | Motorcycles
The bike dies, after a fully charged battery.
Bike has magneito (thats spelled wrong ) On line youtube veido shows how to fix that.
Apr 01, 2012 | MBK Motorcycles
My trimmer wont start. thought it was battery put a new one in worked for a few minutes and then stopped working
your batteries aren't charging fully, check them fully charged with a volt meter,, fully charged they should have a reading of 18.5 volts, if not they are not charging, and either the batteries have used up their life, or your charger is on its way out
Jul 15, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
How do you tell when the battery is fully charged. It continues to show that it is still charging when it would have to be fully charged. The battery is a 3.8V which isn't mentioned on the charger...
The light usually changes colors or goes from flashing to solid even from a light being on it going off when charged. Every camera is different. Normally a good hour will fully charge most camera batteries.
May 13, 2011 | Cameras
Kindle not working. It will not turn on blank screen
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Feb 21, 2011 | Amazon Kindle DX 3rd Generation
Fully charged?
we have to keep some time to charge this LG Vu CU920 as there is no option like fully charged display....... switch off your phone after 10 pm and charge it for 3 hrs or wake up in the mornig make the phone off and charge it for 2 and half to 3 hrs.... then the battery will work long
Dec 05, 2009 | LG Vu CU920 Cellular Phone
IPOD Video 30gm
Hold down on the center button while hold down on the menu button. The apple logo will appear. Your Ipod is now rebooted.
Is the new battery fully charged? Usually it takes 6 hours on a new battery.
Jun 08, 2008 | Apple iPod MA446LL/A MP3 Player
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Palm Charging
Synchronize your E2, then work on draining the battery all the way down in order to reduce the effect of battery memory. Memory happens when we repeatedly partially charge a battery. Over time the battery will forget how to keep a full charge, but will remember how to be partially charged. That's usually when users realize there's a problem. The first step is to drain the battery and FULLY charge it at least fully on the battery's indicator, but if you can, let it sit for 24hrs. The second step is to try to use the battery more before charging it and let it charge fully (ie-overnight) before using it when you need to charge it.
Good luck and let me know how you make out.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
