Question about Microwave Ovens
Kenmore microwave oven 89355 no power
What size fuse do this microwave oven use
SOURCE: Kenmore over the oven microwave
check high voltage section diodes and capacitor or high voltage circuit,
Posted on Nov 04, 2007
  • 338 Answers
SOURCE: I need a replacement fuse for microwave oven model SMW714
20amp
Posted on Apr 10, 2009
najah
  • 180 Answers
SOURCE: Kenmore Micro/Oven fuse keeps blowing
Disconnect the connector to the primary winding of the high voltage transformer. Put a new fuse . If the fuse is not blowing the problem may be in the secondary side of the high voltage transformer. Chek the highvoltage diode, capacitor, magnetron respectively. you can also check the primary winding of the low voltage transformer.
Posted on May 24, 2009
  • 58 Answers
SOURCE: No power to microwave (but electric oven works fine)
hi yes slow blow 500 milliamp take off rear cover you will see it hope this helps merlinv12
Posted on Aug 19, 2009
Testimonial: "Thanks for the advise. It's working again."
SOURCE: Kenmore Microwave Hood Combination oven Model Service code (SE) ?
I have Microwave Kenmore model 401.80082700 about more than a year. After about 6 months, it stated to have some probles such as some number keys not working. Then button START become nor working some times. I can use only button of 30 secon increment to cook something. OK, the fan is working for most of the time but the levels are stuck, not adjustable. I can't changer the fan levels. Now the lamp buton is dead. Sometime, the fan level control is working by itself level 1, 2, 3.... then it appears -SE- on the display. nothing work now. I unplug.... then plug back, it ask to input the time or date... I can't do any thing. Later some time I can cook by using 30 secon button.... It is anoying. Please how I can fix it? Thank you.
Posted on Nov 09, 2009
Fuse replacement Kenmore microwave
Unplug. Remove the top/side panel. The fuse will be obvious near the power cord it is a special non glass fuse used in microwaves. (i save many fuses from microwaves others placed at the curb so mine are always free)
Oct 20, 2013 | Kenmore 63683 Stainless Steel 1200 Watts...
Kenmore 721.80012401
Chances are the thermal fuse is gone that protects the magnetron. Unplug microwave, remove top, [several screws] look over to the keypad and slightly to the left, you should see round fuse mounted on the inner chassis at the top, change with the same size and rating, if all goes well the microwave oven should function.
Jun 24, 2012 | GE JES735WJ Microwave Oven
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
Kenmore elite model #665.61683101, has no power, plug works but microwave has no display, is there a fuse in this model?
There is a line fuse for this oven. Remove the cabinet and the fuse should be close to the line cord. Replacement fuses should be found at your local appliance supply house.
Apr 19, 2011 | Kenmore 62622 Microwave Oven
Where is the fuse in my Kenmore Over the stove Microwave oven
The fuse is located under the keypad in towards the high voltage capacitor "silver rectangular in shape" before you take it apart "unplug and discharge capacitor" there are dangerous high voltages present, the fuse is a ceramic type and must be replaced with the identical size and rating. Now if the fuse blows again it is more than likely one of the door switches is defective.
Feb 09, 2011 | Kenmore 62702 Microwave Oven
Kenmore microwave 80404400 no power
This is typical of the 20 amp fuse blown. It can blow due to slamming the door or even opening the door to quickly while it is running. It could also blow if there is a failure of one of the door interlock switches. This fuse is ceramic and looks similar to a cylinder automotive fuse and is located behind the control panel on this model.
Apr 20, 2010 | Kenmore 80412 Microwave Oven
I need kenmore microwave 665.68680991 schematic
oven is dead. no power. think it is fuse. dont know how to get fuse out or wher eit is
Feb 13, 2010 | Kenmore 63792 Microwave Oven
The oven blew a fuse and now doesn't power on. The electrical outlet is working.
thats a comon fult,,, megertron or capacitor shorts out the fuse blows and wont power up again with a new fuse fitted in the plug,,,,,
there is another fuse inside the microwave likely to be 2 of them and 1 very hight voltage fuse,,, (ei: 1000.s of volts) but there not the same size as 13 amm plug fuses, pluss if you are not to good with microwaves, please dont go inside of it,,, it could and probley will kill you,,be warned
play it safe go out and buy a new one,, think of it this way
how old is the unit now???? and there fairly cheep now from £50 up!!
Oct 21, 2009 | Kenmore 63792 Microwave Oven
Kenmore microwave model 665.61629100
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
May 29, 2009 | Kenmore 63792 Microwave Oven
Nov 03, 2007 | Kenmore 62702 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
