Question about Hoover HDV7FM Electric Dryer
Replace belt on hd vision tumble dryer
Hi replace belt on hd vision tumble dryer
  • 9 Answers
SOURCE: broken belt on hotpoint vtd65 tumble dryer
turn the macine aroun you wiil see3screws on the top holding the lid on remove these and take the top off there are 3or4screwes on the top in front of machine remove these lay the macine back at45degres and on the bottom of machine you will find 4more screws remove these and the front will come off place new belt over the drum and with a small crow bar linked through the belt and under the drive apply a lot of down presure to get it on to drive this is realy hard and you mey think the belt is to small it is not make sure u align drum in to front door or machine this is very simple then re assemble and away you go approx time45to hours work
Posted on Dec 06, 2007
SOURCE: Replacing the Drive Belt
I am not an expert but I do have a Hotpoint 9334 Tumble Dryer which I guess is similar to the 9314.
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly. (This is a bit scary as you have to hit them quite hard and the fingers look fragile)
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Posted on Feb 03, 2008
hards327
  • 30 Answers
SOURCE: How do i replace belt on condenser tumble dryer
you need to remove the whole front of the machine by removing the : top by the 3 screws at the back,then unscrew the screws across the front of the top of the bezel then remove,then open the door,remove the circle of screws then put the machine on its back,remove the screws at the bottom front of the machine,then lift the front bottom of the machine and slide it upwards then you should be able replace the belt then refit in reverse order good luck.
Posted on Mar 17, 2008
AlmostBob
  • 550 Answers
SOURCE: how to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Posted on Aug 29, 2008
SUPERMAN_B_1
  • 294 Answers
SOURCE: How to replace the belt on an Indesit IS60V Tumble Dryer
hello, replacing a belt on a dryer is pretty straight forward and wont use to many tools other then what you need to take the cover off, the only difficult part is keeping the belt on the pulley while getting the belt all the way around the tumbler it may take a few trys but its not imposable when i did mine it took about 10 mins to get the belt on the tumbler while keeping the belt on the pulley if you have somebody that can help you this will make the job allot easier. good luck
Posted on Mar 26, 2009
How do I replace the door switch
Go to espare.com and watch the vidios about that
Dec 04, 2015 | Hoover Vision HD VHC691B White Electric...
How do i get access to the motor on a hoover vhv781c tumble dryer as i need to replace the capacitor
Hoover vision hd tumble dryer VHC680F 16/10/2012 ...
? 0:19
https://www.youtube.com/watch?v=WCiQ9qc2TWk
Oct 16, 2012 - Uploaded by Ben Smith
Ben did you manage to change the capacitor? I got the same problem but I cant actually get close enough to the capacitor to replace it!.
Nov 26, 2015 | Hoover Vacuums
I am replacing the door of my tumble dryer and I need to know haw to assemble.
photo graph it with ure phone then put it back togather in reverse order
Feb 06, 2015 | Hoover Vision HD VHC691B White Electric...
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
How to access belt on indesit idv65 tumble dryer
Indesit tumble dryer not turning? How to replace a Indesit tumble dryer belt.
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
Jun 22, 2012 | Dryers
Need to replace belt on vtd20g hotpoint tumble dryer
May 10, 2012 | Dryers
How to fit a drive belt to a indesit g511v tumble dryer
http://www.apart4u.co.uk/video-tutorials/tumble-dryer-repairs/how-to-replace-a-belt-on-a-tumble-dryer-stretch-type.html
Hi the above web page is a good general instruction video on how to change a tumble dryer belt, should help, if it does please remember to rate me
Feb 24, 2011 | Dryers
Hi, My 8kg Hoover Tumble dryer Vision HD stopped working, first a filter care light, so cleaned the filters and now the light comes on but nothing happens. Any ideas? Thanks Matt
try drying the inside of where the water reservoir is.also water may be collecting in a hole on the base of the condeser hosing.
Jan 08, 2011 | Hoover Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
How do i replace drive belt on an indesit is60v tumble dryer please
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts from How to Repair Home Appliances
Sep 09, 2009 | Dryers
Hoover HDV7FM Electric Dryer Logo
225 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
