Question about Kenmore 24 in. 15689 Built-in Dishwasher
Cannot fill due to float - Kenmore 24 in. 15689 Built-in Dishwasher
My Kenmore Portable Dishwasher model number 665.17769K600 will not fill with water, I have to manually fill with water and it will then work. What could be causing this?
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 24, 2011 | Kenmore Dishwashers
My dishwasher does not fill with water
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Feb 21, 2011 | Bosch SHU5315UC Dishwasher
My portable dishwasher won't fill? Please help!
Hi
Daniel
Feb 20, 2011 | GE Dishwashers
Will not fill with water
Hi
Daniel
Feb 13, 2011 | Whirlpool Dishwashers
Hi
Daniel
Nov 27, 2010 | Zanussi ZT485 Built-in Dishwasher
Dishwasher is not filling up with water
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter hen you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Oct 25, 2010 | Hotpoint Dishwashers
Dishwasher will not fill with water
Hi
Daniel
Oct 07, 2010 | Bosch Dishwashers
Will not fill and will not run even when filled by hand.Is it the circuit board?All fuses and switches are good.
Hi
When the Dishwasher is not filling in, you’ll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don’t get any value on the multimeter hen you'll need to replace the water inlet valve assembly.
Daniel
Aug 26, 2010 | Hobart Dishwashers
Not filling
Hi
Daniel
Aug 20, 2010 | Electrolux 23 in. ESL624 Built-in...
I am not getting any water to fill the tank for washing
Hi
Daniel
Jul 24, 2010 | KitchenAid Dishwashers
Kenmore 24 in. 15689 Built-in Dishwasher Logo
99 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
