Security code radio pin code
SOURCE: blaupunkt radio security code not working on my Holden Astra
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Here is a video showing how to remove your radio from the dashboard. A pair of extractors are required (available from Ebay , etc) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
http://www.fitaudio.com/videos/din_keys_guide/video_din_size.html
SOURCE: How do I enter the radio pin code (which I have)
press and hold AS button for a couple of seconds till beep is heard and CODE----
is displayed in the display
use the preset button 1to get 1st number then preset button 2 to get second number etc.... until all 4 digits are entered then press and hold AS button again until beep and radio should start working
SOURCE: 2000 Holden Astra - Hi there, I require a radio
If you have removed the radio from the car or changed/disconnected the car battery sometime back then you need Jaguar radio unlock code to get the sound back. You can purchase it from here.
There are few ways to unlock the radio
1. Refer to your manual. You must be having the code as well as the procedure to unlock it.
2. If you do not have the code then you can purchase it online. You will get the code within a day. For that you have to collect 2 information.
a. VIN - Vehicle Identification number, usually found at the bottom of the driver side windshield.
b. Radio serial number. You can get it on the top of the radio after removing it from the car.
c. You can purchase the code from here.
SOURCE: unlock stereo code for holden vectra 2000 model
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Holden service centre and get them to enter this code for you.
