Question about Tecumseh Garden
Tecumseh hmsk80 oil coming out breather - Tecumseh Garden
3 Suggested Answers
  • 371 Answers
SOURCE: oil blows out of tube
You either have a head gasket going bad or your piston rings are shot which causes air to go down into the crankcase building up pressure which exits through the breather tube.
Posted on Feb 01, 2009
  • 306 Answers
SOURCE: tecumseh ohh55 smoking/burning oil
http://www.repairclinic.com/Tecumseh-Small-Engine-Model-OHH5569024F-ID-806444-Parts
one of many suppliers on the web- lol
Posted on Jan 29, 2012
How to adjust governor on a Tecumseh hmsk80?
Static Governor Adjust.
With the engine stopped, loosen the screw holding the
governor clamp on the governor lever. Rotate the clamp in
a direction that will force the throttle shaft open and allow
the governor follower arm to rest on the governor spool.
Push the governor lever connected to the throttle to the
wide open throttle position. Hold the lever and clamp in
this position while tightening the screw.
Feb 27, 2015 | Tecumseh Garden
10 hp tecumseh throwing oil out the breather tube
There is excessive blow- by from the combustion process which indicates worn rings /broken rings or scored bore (engine worn out or dusted). Check oil level in sump as excessive oil will also cause the problem
Mar 09, 2013 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Tecumseh ohh55 smoking/burning oil
Jan 07, 2012 | Tecumseh Garden
Have airens rocket tiller 901006 when running oil come out of tube beside carb. have try about every thing even new rings and it still does it was it had shut off vale can't fine one any help would be...
from a Tecumseh service manual...
Breather passing oil:
-Oil level too high
-Excessive RPM or improper governor setting
-Damaged gaskets, seals or O-rings
-Breather damaged, dirty or improperly installed
-Piston rings not properly seated or ring end gaps are aligned
-Angle of operation too severe.
I had the same problem on the same machine as yours. So hapened the breather was installed upside down... a small hole on the side of the 'cup' should be pointing downwards to allow oil to seep back in engine. Clean the breather assembly thoroughly before reassembling.
Make sure to never overfill with oil.
May 30, 2011 | Ariens Garden
8 hp tecumsch engine for snow blower oil comes out the side vent tube when running
replace the oil breather filter and make shore you did not over fill the moter with oil
Jan 16, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I have a Sears Craftsman mower with Tecumseh, major oil leak
On many Tecumseh engines, there is a crankcase breather located under the flywheel. It has a cork gasket to seal the top plate of the breather. Either the rubber breather housing is cracked, or the cork gasket needs replaced.
Nov 07, 2009 | Craftsman Garden
I want an owners manual for a Tecumseh 4 cycle engine model number hmsk80
Hey,
I've found the online manual for your machine. Try, http://www.cpdonline.com/692509.pdf
Hope this helps.
Thanks
Apr 10, 2009 | Sport & Outdoor - Others
Oil blows out of tube
Jan 31, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
56 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
