Question about Refrigerators
Fridge model#MBR2255kes. The freezer works fine,
Fridge model#MBR2255kes. The freezer works fine, but the fridge above is not cooling. All the food went bad and I'm looking for solutions. This fridge was exceptional until three days ago and I've not done anything considdered different while using it. What should I check and what are the possible causes of this malfunction (door seal seams fine).
  • Refrigerators Master
  • 4,655 Answers
Your refrigerator has a control board located inside the fresh food compartment. It is hidden behind the temperature control panel. This board could be your problem. Your fridge also has air dampers that are controlled electrically. We will still need to check the defrost element behind the freezer wall. Most times when this happens the problem is related to a control board or defrost timer. If you want to check these things yourself unplug the refrigerator and look inside the control panel to see if your board has burn on back and front. If you don't find burns on board then we will open the back panel in freezer to see if the coils are frozen over. You are free to ask my help if you like I will be here. You also can go to site link below and enter the model or part number in search feature. Let me know what you find, Thanks, Sea Breeze
Click link here V__V__V
http://servicepartstec.blogspot.com/
Enter model first then it will take you to pictures of your model. On left side of screen choose photo # 3. When you click on photo 3 the part is # 5 in the photo. The part I think is the problem is part #
12868513
Let me know what you find, Thanks Sea Breeze
Posted on May 18, 2009
Kenmore fridge, model 253.63754302 freezer working fine, main fridge not cooling much (approx 62 degrees F.) Have been away for 7 months. Usually plug it in to restart and all works fine. Not this...
Your refrigerator is made by frigidaire it sounds like your damper is opening up if your freezer cold and the fresh food compartment isn't.
Nov 03, 2013 | Kenmore Refrigerators
I have a kitchenaid, KSRS25RSMS01, refrigerator and the freezer is fine and the fridge is not cooling. I have checked the evaporator and it has normal frost, and the fan is turning fine, but the air coming...
Your frig has the classic symptoms of a frig with a clogged or blocked vent between the
freezer section and the refrigerated section. This clog can occur due to (a) stuff in the freezer blocking the vent, or (b) ice in the freezer blocking the vent, or (c) both of the above.
The way a refrigerator works is it cools the freezer, and the warmest air in the freezer is vented out
to the refrigerator section. If this vent is blocked (and everything else is working), your refrigerator
just became a eye-level small freezer atop a well-insulated section of dangerously warm food.
May 13, 2011 | Refrigerators
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
Freezer temperature working fine fresh food
I need you to confirm that your model number is ZICS360NR and I will help you, Sea Breeze
Nov 13, 2009 | GE Monogram ZICS360NR Bottom Freezer...
Fridge not cooling
freezer works, fridge light works, fridge cools a little but not much, food goes bad in couple of days
Nov 13, 2008 | Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Maytag MSD2650HES Stainless Steel Side by...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Feb 21, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Refrigerators Logo
212 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
