Question about Denon AVR-2105 Receiver
How to fix the protection mode - Denon AVR-2105 Receiver
Amp Protection Mode
TRY DISCONNECTING IT FROM THE BATTERY FOR ABOUT AN HOUR. SEE IF THAT HELPS.
Nov 17, 2013 | Car Audio & Video
Kenwood KDC-MP732 CD Player in protect mode how do i get it off had a blown speaker fixed it and still in protect mode
Protect Mode (Blink): The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated.
Solution: Wire or insulate the speaker cable properly and press the reset button.
Here is a copy of the Instruction Manual for the Kenwood KDC-X790 and KDC-MP732.
Jul 25, 2010 | Kenwood KDC-MP732 CD Player
In protect mode
my cd player is in protect mode. what can i do to fix it??
May 10, 2010 | Kenwood KDC-MP242
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
My nitro bmw-486 amp is in protect mode how can I
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty De .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-bmw-486-amp-in-protect-mode-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
Feb 24, 2010 | Nitro BMW-486 Car Audio Amplifier
My Stereo Is Always On Protect Can It Be Easily Fixed
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 27, 2009 | Sony Audio Players & Recorders
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
DUB 2502 Protection Mode help
The most common reason for an amp to go into or remain in protect mode is shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Aug 07, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Amp comes on and goes right into protection mode
Turn the reciever on for a second or two and then off before the protect mode shows up on the monitor. Repeat this step about five times and check to see if the reciever does not go into protect mode. If it does go into protect mode try it again. Dont know if this is the proper way to fix the reciever but it worked for me. Good Luck
Mar 09, 2008 | Audio Players & Recorders
Protect Mode
Is it doing this while you have it turned right up? Most systems have protect mode because you are trying to draw to much power or amps through them. Are you trying to run to many or to large of a speaker through them all systems have rate output if you try to exceed this they go into protect mode so you don't blow the amp.
Dec 10, 2007 | Onkyo TX-DS676 Receiver
Denon AVR-2105 Receiver Logo
83 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
