Question about FoodSaver V3880 Vacuum Sealer - The Master Chef Kit
Tray full light stays on - FoodSaver V3880 Vacuum Sealer - The Master Chef Kit
3 Suggested Answers
  • 10291 Answers
SOURCE: foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Posted on Jun 07, 2014
Tried the recommendation above, even have let it air dry for more than an hour, there is nothing moist around the three contacts. I, of course am in the middle of a huge project!
Posted on May 28, 2016
Where is vacuum chamber on a Windsor sensor xp12
it comes up from the back,it is probably plugged or the sensor is dirty
Apr 21, 2015 | Windsor Vacuums
Foodsaver vacuum sealer tray full light
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
V3835 tray full light won't go out after both trays have been emptied and cleaned.
Hair dryer. Remove both tray inserts and dry thoroughly, paying special attention to the sensor area in the center of the upper tray.
Sep 26, 2013 | FoodSaver V3835 Vacuum Food Sealer with...
The tray full light stays on even though the tray is empty.this prevent the foodsaver from operating.I have tried unplugging,recleaning the tray but nothing works
I had the save problem with my 3400 series.
The first time i was able to let it dry and it worked alright (48 hours).
The second time even this did not work.
If you remove the screws on the bottom of the unit. There are about 10 and pull it down, you will see the sealer assembly and a small circuit board in the middle.
Trace the wires from the drip tray, there are three of them, red white and brown, to the small white plastic JST connector on the small circuit board. Pull said connector gently to disconnect it.
The unit will function perfectly now, although it will no longer have a drip tray sensor of any sort it will function every time all the time.
All in all this took me about 10 minutes.
Thanks!
Sep 09, 2010 | Vacuums
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
The dial regulating suction does not seam to work the vacuum works constantly on the full power and the light indicating overheating stays on.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This would depend on the brand and model number you have – without knowing the model or brand of vacuum you have it would be hard to give an accurate answer – the over heating light could indicate some type of clog or blockage and may have nothing to do with the dial to regulate the suction – that merely is a height adjustment …. As this does happen to most vacuums that the overheating light comes on – if there is no problem have it looked at from your local vacuum dealer or repair shop would be the best advice that I could give you.
Apr 15, 2008 | Vacuums
Red light stays on
Most likely the hose or the inlet down by the brush roll has a clog in it. The red light indicates a full bag, but if there is a clog, then it thinks it has a full bag.
Dec 07, 2007 | Lindhaus Activa 30-38 Bagged Upright...
FoodSaver V3880 Vacuum Sealer - The Master Chef Kit Logo
125 people viewed this question
Top FoodSaver Vacuums Experts
Lawrence Oravetz
ray gallant
Edd
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
