Question about Kenmore Elite 45986 Front Load Washer
Washing machine stops and gives an F and an H error.
Please advise. Thanks
  • 15,935 Answers
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
What would stop a bush a126q washing machine draining, it just stops in the middle of a wash cycle?
hi i have a BUSH A126Q model W/M .Spin and Drain dosnt work. I clean the FILTER but same problem. Error code is Err 03. The start light & program ready light is blinking when M/C go to spin / Drain.
Its looks pump dont work //////
Please advise me what to do ???????????
Thanks
Mar 19, 2011 | Washing Machines
I have the Kenmore Elite Oasis HE washing machine and it constantly stops the washing machine and displays the F1 error code. Has this machine been recalled? I have read several complaints from other...
Hi
Error Code F1 means that the control is either bad or the wiring harness to the control has some issues. Please check the control board for any bad components as you might need complete replacement of the control. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Kenmore Washing Machines
Hi, My washing machine, Fisher and Paykel, MW 511 PRIDE would not do the SPIN cycles. Please advise. Thanks. Sam Lee
Hi Sam Lee.Now , does the machine drain the water?If it does drain the water does it stop and beep and show an error code?if it does the error code will be a series of lights that will light up when the machine is beeping.They will be on a row of 8 lights.Starting from left to right which lights are lit when the machine beeps,Is it the 2nd and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 03, 2010 | Fisher and Paykel Washing Machines
Front loading whirlpool stopped part way through wash with a F 21 error message. Please advise. Thanks; Kelly
Hi Kelly,
Thanks for using FixYa. Error F21 means long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Washing Machines
ERROR E7 TOSHIBA WASHER AW8960S
check the water level switching or door sensor
Sep 09, 2009 | Washing Machines
Error code F20
take the kick panel off inside you will find the tech sheet it will give you a list of error codes. i believe you have a bad pressure switch or it could be something stuck in your pump. untwist and check the pump filter. let me know how it goes
Dec 24, 2008 | Kenmore Elite 45986 Front Load Washer
CA Error Code - AEG OKO LAVAMAT 86700
c-a error message poped-up.washer stop working.............please help.
Sep 15, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Hotpoint aquarius shower
water pump clogged with debry clean out
or the your home lost preasure in pipes
Mar 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Ariston Washing machine A1636 - Flashing lights
what 2 lights are flashing each light that flashes gives a differant fault code . Get back to me
Jun 20, 2007 | Ariston Technologies AW149NA Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
