Question about Sony KP-65WV600 65" Rear Projection HDTV-Ready Television
Screen intermittently flashes green/eventually shuts off
When the tv is turned on, it will intermittently flash screen between displaying the normal screen. After a few minutes the TV shuts itself off. Any idea what is causing this and the cost of repair if it is not something I can do?
  • gator149 May 17, 2009
    Sony KP-65WV600
    President:
  • Sony Master
  • 1,114 Answers
What type of TV
Posted on May 17, 2009
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
When i turn on tv the screen flash green
It is a bad symptom. Might be related to its display panel. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 19, 2014 | LG DU-37LZ30 37 in. LCD HDTV
MY SONY KP41T35 PIC FLASHES ON OFF ON OFF AND GREEN PROJECTOR IS ON BUT NOT SENDING PIC JUST GREEN LIGHT
Sony PTVs do get bad CRTs, to confirm you can pull the front cover and tap on the middle CRT (green) neck with a plastic handle if the green screen flashes back to normal or brighter and causes the TV to shutdown then the CRT is bad. sometimes you can make it stay working for awhile, but eventually the CRT will need replacing. if this doesn't help you can turn the bottom middle control counter clockwise to lower the green .
hope this helps
Eric
Aug 17, 2009 | Sony KP-41T35 41" Rear Projection...
Power flashes green then turns red; Lamp flashes red.
is this a flat screen first off
if it is 90% of the time the vid card has over heated they have a video card kinda like pc's one thing is most companies dont put fans on them so they over heat especially when dust start collecting on it wait and see if anyone else has any thoughts on this but im pretty sure thats it you will need to take it to someone that works on tvs to replace it and also ask them if they will install a fan on it
but like i said wait and see if anyone esle has any thoughts on this first
Apr 28, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
Screen flashes green a couple times then shuts off
you need a new green CRT. The lines were retrace lines which are the first sign of a tube developing a short eventually the green will short completely and cause the set to shutdown.
Feb 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
Green color comes on and off
I need some answers here... Do you have only one video source to test it? Is this happening with an external source or with your tv tuner or both? I need more info....
Aug 10, 2007 | Samsung HCL4715W 47" Rear Projection...
Sony KP-65WV600 65" Rear Projection HDTV-Ready Television Logo
133 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
