Question about Konica Minolta magicolor 2400 Laser Printer
Konica Minolta magicolor 2400w will not print
I have perused posted problems and suggestions and I think that my paper feed roller needs a tension adjustment or a replacement. There was one reply with directions for adjusting tension that I couldn't figure out because taking off the back door to the printer didn't give me access to anything. I also have cruised the web looking for a way to order said part and have come up empty-handed. Any suggestions for adjusting the roller or getting a replacement part would be welcome!
  • Konica Minolta Master
  • 6,696 Answers
Will print??? or the paper not coming out of the draw does it work using the bypass tray???
Posted on Jun 11, 2017
  • 214 Answers
SOURCE: konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
Posted on May 27, 2008
  • 3 Answers
SOURCE: Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Posted on Aug 11, 2008
  • 118 Answers
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Posted on Nov 18, 2008
whytfang
  • 170 Answers
SOURCE: Konica Minolta 2400W Magicolor. Error light blinking
Ready indicator Error indicator Condition Action
Green Orange
Blinking Blinking Communication Check The Printer
error cable
____________________________
Print over-run Turn off the printer.
After a few seconds
turn on the printer
change to a lower
resolution.
________________________________________________________
This may help if not...let me know........Whytfang
Posted on Mar 25, 2009
DLBurkhart
  • 210 Answers
SOURCE: I have a Konica Minolta magicolor 2400w printer I
For the language problem, reinstall the printer driver, selecting "EN" for the language to be in English, not "ES".
For the print problem, there is not enough information to diagnose. Please detail the symptoms. If you meant indicate that the printer recognizes an attempt to print, there should be a message on the LCD panel and certain LED lights indicating what is happening. We (the solution providers) need to know exactly what that is.
Posted on Aug 31, 2009
Magicolor 2400w paper jam error at transfer roller
In correctly installed transfer belt. and or roller reseat both. do the internal l machine prints demo page etc. jam if not check the print properties and paper setting of the machine in the draws they must match one could be set to letterhead paper the other normal both have to match.
Feb 10, 2014 | Minolta magicolor 2400W Laser Printer
Text is printing too low on the page
I have a Magicolor 2400w and had the same problem... I hope I'm not to late because I almost put mine in the trash.
How I fixed the problem was I adjusted the solenoid behind the fan on the right side. I made a video and posted is on YouTube. Search YouTube for Magicolor 2400w paper size error. or follow the link.
http://www.youtube.com/watch?v=jlyuPJW6RjU
Hope this helps
Dec 29, 2012 | Konica Minolta magicolor 2400 Laser...
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Paper feed issue
You didn't setup the paper size correct, check again in the driver and application to have the same dimension with the actual paper in printer.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jun 04, 2009 | Konica Minolta magicolor 2400 Laser...
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Konica minolta magicolor 2400w printing proplem
May 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
2400w Konica Minolta Magiccolor
dont understand your problem quite well, but, for a connection problem, update driver, change usb cable and last if nothing helps, update firmware.
for a paper take up problem,:
turn off printer,
remove cover,
remove drum cartridge,
under that there is take up roller, pull the knob and move the roller to right, then you can pull the take up roller out.
first try to clean it and also clean plate under the take up roller. if thats not helping, then you have to cut the biger (larger) plastic sides of the take up roller a little smaller..
should help.
good luck
Feb 10, 2008 | Konica Minolta magicolor 2400 Laser...
Magicolor no longer grabs thicker papers
I think you need to clean take up roller first, and then set the settings in printer propertis in thick paper.
shold work.
cleaning:
open cover, remove imagine unit, then you can see the take up roller. clean it.
Dec 25, 2007 | Konica Minolta magicolor 2400 Laser...
Paper jamming, not feeding through evenly with rubber rollers
clean the rollers with propanol whcih is available small bottles with hardware vendors or with chemists. clean the rollers carefully with that try a print. if it not works then consult your service centre.
Apr 06, 2007 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
263 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
