Question about Emerson Audio Players & Recorders
Hook up emerson plug and play karaoke
My tv does not have the cooresponding color coding, so although I can hear the cd, the microphone is silent
snakehead
  • 1074 Answers
SOURCE: Black and White
There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
Posted on Apr 03, 2007
SOURCE: microphone sound not working
you cant do it
Posted on Sep 29, 2008
SOURCE: hooking dvd player up to tv
Sounds to me as if you have not set the Playback CODEC properly.. In the Menu system, as in NTSC or PAL. Make sure that the DVD & Player are set the same Format ie: NTSC or PAL..
Posted on Nov 30, 2008
SOURCE: can a xbox 360 play cdg discs like for a karaoke?
no it wont
Posted on Dec 23, 2008
  • 28 Answers
SOURCE: Karaoke CD's will not play on Craig CD+G player
This is a problem with a simple answer. As newer disk technology comes out, newer electronics come out to work with them. Most likely your Kareoke machine is older and not compatible with burnt cds. As long as you are ok with buying regular CD+G disks, you should be fine. If you are interested in making or copying CD+G disks from others, you should consider investing in a new Kareoke machine. As per your question of it being correctable, to my knowlege, No. The electronics in older kareoke machines are not meant to handle CD-Rs or CD-RWs and in order to correct it you would have to somehow frankenstein a new circuit board in somewhere to allow it to handle CD-R/W Disks. As I don't know what is necessary, I am not sure if this is even possible. Like I said if you need this function, you are better of just getting a new Kareoke machine and selling your old one to offset the cost. Make sure the new one handles CD-R and CD-RW disks. Some more expensive ones will also handle Kareoke DVDs as well and have an A/V out so you can display the information on your TV(some of them will even handle DVD-Rs as well). Just look for that information on the box or ask a store representative for that information and they should be able to help you.
Posted on Mar 22, 2009
The CD is playing on my kids hello kitty kids karaoke machine, but u can barely hear it. Microphone sound is loud. What is wrong?
1st try a different cd , also look for a MIX knob most karaoke machines have them , this might be out of adjustment
Feb 26, 2016 | Music
How do I get the lyrics to play on the screen using the karaoke anywhere app? I hear the music but there's no lyrics
The Karaoke Anywhere app will play standard MP3+G zip files. These contain two files. One must be an mp3 file and the other must be the accompanying cdg file. The zip file cannot contain any other files or folders.
It seems from what you describe, the file you are attempting to play through Karaoke Anywhere is an MP3 file but that it either does not have a proper CDG file, or the MP3+G zip file is not in the proper format.
Sep 01, 2014 | Sakar The Voice I Want You CD G Karaoke...
I accidently put the rca wires in the wrong audio input/output on my craig cd graphics karaoke player.Could this be why i have no sound?
The RCA outs are designed to send a signal to an external amplifier. That amplifier, in turn, sends the music signal to speakers.
The RCA inputs are designed to take audio signals from another device (like an ipod, CD Player, or computer) and play it through the Craig System speakers. If you sing into the microphone, the vocals will be mixed with the incoming music. However, in these cases, there won't be lyrics on the screen. If you play a karaoke DVD in a DVD player, connect the red, white and yellow RCA cables from the DVD out to the Craig Inputs, the lyrics should appear on the Craig screen while the music plays.
If you mistakenly plug RCA cables into the Craig Inputs and plug the other end into an amplifier's inputs, neither will produce any sound.
Using RCA outs is only necessary if you want to have louder music than the on-board Craig speakers can handle. Of course, you can run the yellow video cable to a TV RCA input to get a bigger lyrics window and the RED and White RCA to the TV RCA Red and White inputs to hear the music through the TV's speakers.
Aug 30, 2014 | Audio Players & Recorders
Plug broke..can it be fixed by splicing a new plug on it? If so how do we do it? Also lost instructions on how to use are these available?
I can't really guess what plug you are refering to since there are more than one... Power? Microphone? Any competent electronic person that can solder wires can repair this. If cables break for instance at microphones one may have to crack open the shell to shorten the cable a bit and resolder a couple wires and glue it back together... If the plug at the end of a cable is broken, get part at a Radio Shack...
Apr 30, 2011 | Emerson Fans Dual Plug N Sing Handheld...
No sound when cd is playing, or on microphone
probably the amp section- I am working on a STVG-700 right now, the audio amp is mounted on the lowest circuit board in the case, includes the power supply except for the transformer. There are fuses mounted on this board, with luck that's all that blew on this. I know this problem is months old, but if you're like me and didn't get it fixed quickly, it's still sitting around somewhere...
May 26, 2009 | The Singing Machine SINGING MACHINE...
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
