Question about Daewoo FRSU20IC (21.8 cu. ft.) Side by Side Refrigerator
Freezer not freezing food
The fan section doesn't seem to be working correctly, the food is staying part frozen but not solid. It's also making strange noises
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Daewoo FDF-358 fridge is taking a couple freezer
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 11, 2011
omiga man
  • 452 Answers
SOURCE: daewoo american fridge freezer not freezing and not making ice
I think it is your thermostat this controls the motor theirs a top 1 & a bottom 1 they both control the motor 1 4 freezing the other chilling because u say they are both not working it is also posable that ur f/frezer may need re charging
Posted on Sep 03, 2012
Freezer not freezing, some things are not frozen solid, but fridge seems to be cooling properly
One thing to do is clean the coils around the compressor so that air can move freely over them.
Dec 12, 2012 | Refrigerators
Our chest freezer isn't keeping food on top frozen although the bottom is still frozen solid?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help in solving the problem....
Jan 11, 2011 | Freezers
My fridge is freezing food in the fridge section. The eggs closest to the freezer are all frozen, vegetables are frozen.
the cold control and air deflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this help in solving the problem....................
Aug 15, 2010 | LG LRSC26922S Side by Side Refrigerator
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator not cooling
sounds like the fan in the freezer isn't working.
Mar 21, 2009 | Whirlpool ED5VHGXM Side by Side...
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
The evaporater is located in the freezer section of unit.Defrost thermostat is cliped on the top of it. This is no doubt the culprit. You will need to check continuity on defrost heater and replace themostat.
Jul 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Jan 05, 2007 | Maytag 22.6 cu. ft. Side-By-Side...
Daewoo FRSU20IC (21.8 cu. ft.) Side by Side Refrigerator Logo
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
