Question about Philips Magnavox Learning Universal Remote
Remote control i have a philips universal remote control..the only numbers i can find on it is..CLO19 and 43/05. i cant seem to get anything to work on it but the tv code..i cant get the sat/cbl button to work on my cable...i need codes i think..please help
  • 1 more comment
  • lex5 Nov 14, 2007
    i need the remote control codes
  • Anonymous Jan 03, 2008
    need the manual for clo19
  • Anonymous Aug 19, 2008
    need code for tv apex philips universal tv control CLO19 49/05
  • 73 Answers
SOURCE: universal remote codes
try this website it might be of help.
Posted on Jan 02, 2008
  • 2712 Answers
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands of devices from
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
Posted on May 07, 2008
SOURCE: Codes for my Philips universal tv remote control
I have the remote control but i need the code to add in my toshiba tv
Posted on Jul 12, 2008
SOURCE: i need codes for philips universal remote control
I have a phillips universal remote, that I brought in Georgia. I have lost the instructions for programing.
My television is Emerson and I need the codes and instructions. Please help.
Posted on Oct 01, 2008
Posted on Jul 06, 2009
What is remote control code for 42 inch vizio tv with phillips universal remote
Your Philips remote is universal so you can use its "code search" feature to find a suitable code. The codes are stored in the remote. If a thorough search does not produce a code, you may have to try another universal remote because not ll codes are stored in all remotes.
Oct 07, 2014 | Philips Phillips SRP1103/27 3-Device...
Lost remote and trying to use a phillips universal remote but cant find code
Regarding your remote control, Philips Magnavox - universal remote control, below is a link to to the user's manual for this and a couple other remotes that share this model number. Click below, choose your remote and the click the PDF user's manual. In the search box, type in the word, "code" and all things pertaining to setting a code will be displayed each time you press enter.;jsessionid=32D289AB3A01E1801AE80FF55AF1E3FE.app106-drp1?userLanguage=en&userCountry=us&_requestid=515863
Hope I helped Dr Reed
Mar 17, 2010 | Philips Magnavox Learning Universal Remote
Cant find the code to program the RCR311W to run my Philips 19ps45s.
If you can return the remote, I'd pick up a harmony remote from Logitech (they all work fine). It doesn't use codes, just the model numbers of the device. They support 55,000 devices and I have never found a device that they won't control (sorry, I know this isn't the advice you were looking for, but this will make your life easier).
Mar 11, 2008 | Universal Remote Control DIRECTV Universal...
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
I cant program a phillips universal remote to my tv/dvd/vcr combo
Shoot both philips remote and emerson tv.... then light cig and calm down.
Dec 05, 2007 | Philips Magnavox Learning Universal Remote
Lost remote codes
i need a code for a philips universal for my dvd player it is a daenyx
dv-5002 cant seem to get it too work i might have wrong code thanx
Dec 03, 2007 | Philips Magnavox Learning Universal Remote
Philips Magnavox Learning Universal Remote Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
