Question about KUL 30 Pint Dehumidifier
Need a replacement filter - KUL 30 Pint Dehumidifier
What should I do when the air filter light comes on?
Good Afternoon Friend, that's a great question!
Typically the FILTER RESET light will illuminate after 250 hours of operation. To locate the filter, remove the bucket and the pull filter downwards. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions. Hope this helps! - Z
Sep 11, 2014 | Frigidaire FDL50R1 Dehumidifier
Removing the filter model fdl7051
Hello Friend, this is Z. Thank you for allowing me to assist you!
You would need to remove the bucket to locate the filter of your Frigidaire dehumidifier (FDL70S1). Then pull the filter downwards for cleaning. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions and typically the FILTER REST light will illuminate after 250 hours of operation. Hope this helps!
Aug 12, 2014 | Frigidaire Dehumidifiers
How can I purchase a replacement air filter for keystone kstad70b?
The filter in your Keystone KSTAD70B is meant to be washed. It is not listed as a replacement part in the owners manual. This is copied from the manual:
3. Clean the air filter
Remove the filter every two weeks based on normal
Remove the filter from the top of the unit (See.Fig.11a),
or to remove the filter,remove Bucket then pull filter
downwards (See.Fig.11b).
Wash the filter with clean water then dry.
Re-install the filter,replace Bucket. CAUTION:
DO NOT operate the dehumidifier without a filter
because dirt and lint will clog it and reduce
performance.
If you have lost or destroyed the filter, go to Amazon and order the Duck Brand 1285234 Replacement Air Conditioner Foam Filter, 24-Inch by 15-Inch by 1/4-Inch, 1-Pack for 96 cents with free shipping as an add-on item to any order. It is also washable so you will be able to use it like the OEM filter material.
Jul 06, 2014 | Keystone Dehumidifiers
How to locate and replace internal filter?? For frigidaire
I understand that you are trying to locate and replace the internal filter for your Frigidaire dehumidifier, model# LAD304NUL. I also see that you cannot find your manual. To locate and replace the filter, follow these easy steps.
a. Remove the filter every two weeks based on normal operating conditions.
b. To remove the filter, remove Bucket then pull filter downwards.
c. Wash the filter with clean water then dry.
d. Re-install the filter, and then replace Bucket.
I have also included the link for your manual, where I found these instructions. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
May 30, 2014 | Frigidaire Dehumidifiers
Water filter on aprilaire model 700 light keeps flashing
You need to reset by turning thermostat dial all the way to test reset. It will reset itself, then go back to your setting.
Mar 05, 2014 | Aprilaire 700 120V Power Fan Humidifier...
How to get to the filter
Take out the water tray as if you were gong to empty it.
Take it all the way out.
Now you should see the filter tab just sticking out, above the water trap access compartment.
Slide it down and out. (Hold the tab and pull down firmly) it should slide out.
Hope this helps
Feb 10, 2014 | Windchaser MDH-W Dehumidifier
Needs new filiter
Unless the filter is totally warn out or destroyed, it's not necessary to replace it. As it is washable in warm water and mild dish washing liquid. Rinse and dry thoroughly before reinstalling it. Never operate the dehumidifier without the filter in place. Doing so can damage the unit.
If you need to replace it, in the USA call 1 (800) 865-6330.. In Canada Call 1 (888) 335-6644.
In Mexico call 800-711-8805.
I hope I was able to help you and thanks for choosing FixYa.
Aug 09, 2011 | DeLonghi DN40G Dehumidifier
Do i need to change a filter?
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=291198
here is the air filter replacement (or just pull out and clean your self
here is the breakdown for all parts for your unit
i didnt see another filter unless you see one in the back
hope this helps
Apr 05, 2010 | Goldstar DH304 Dehumidifier
Should I clean or replace the air filter?
You can wash the filter with water, no problem. However, I would recommend replacing the filter every 3 to 4 months depending on how much you use the dehumidifier. The exposure to constant moisture will cause the filter to grow mold over time.
Jul 27, 2007 | Amana DK25 Dehumidifier
KUL 30 Pint Dehumidifier Logo
26 people viewed this question
Top KUL Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a KUL Dehumidifier Expert? Answer questions, earn points and help others
