Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Lense won't pop out
When I click on the lense it won't pop out. I currently have a canon powershot sd400. Please help
  • mvasquez24 May 17, 2009
    battery is charged able to look at pictures when I click on picture doesn't pop out give me a couple of beeps then shuts off
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
jbreth
  • 69 Answers
SOURCE: as a webcam
No I am afraid you cannot use this as a web cam. I have asked Canon about this and they said that it isn't capable. Sorry
Posted on Aug 26, 2007
  • 266 Answers
SOURCE: Canon SD400 Powershot wont turn
I read a part solution on your web site about my Canon sd400 failing to start. The message gave a few free words about a micro swith in the cover. I couldnt find it! I called Canon tech and they said there was jo such switch. I packed up the camera and sent it off for a fix and a free firmware update. Probably going to cost $80. But I think it was the right thing to do!!
Ian
Posted on Jul 23, 2008
kenshin99
  • 89 Answers
SOURCE: Hi. My Canon Powershot sd400
Hi!
You have to unlock your memory card. All memory cards have this small lock mechanism on the side.
Make sure that the slider is on the UNLOCK position. If it's already on the UNLOCK position and you are still getting the same error message, try to set it to LOCK, then set it back to UNLOCK position.
I hope that helps.
Good luck and have a nice day!
Posted on Nov 26, 2008
  • 7 Answers
SOURCE: I bought a 4g SDHC card for my camera canon powershot sd400.
Well, first of all, I'm not exactly an expert on this, so please don't rely solely on my response.
It's possible that it needs an SD card, not an SDHC card. SDHC cards are high capacity, and some cameras just aren't able to use them because they're set up for the plain SD cards. Does it say what kind it needs in the manual? I think, if it's an older camera, I'm not sure what age exactly, they can't use SDHCs. Like I said, I'm not an expert, so you might want to get more info, if you can. Hope this helps.
Posted on Feb 16, 2009
  • 11967 Answers
SOURCE: I have a canon powershot A530. My camera has been
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 15, 2010
Canon Powershot SD400 won't upload pics to computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 30, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera turns on but shutter does not open. green light comes on then it beeps twice and shuts down. You can view pictures fine though
You mean SD400 camera doesn't show any error sign and it just doesn't have live view to shoot picture?
If yes, its problem of bad CCD imager and Canon will provide free of cost repair facility for SD400 camera.
Click Canon CCD Advisory for details.
Oct 24, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Delete photos
The Canon PowerShot SD400 has no internal memory. All pictures are recorded on a memory card.
Aug 27, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Tranfering pictures
use the usb cable, the pc will see it as an external drive, pics will be in the dcim folder
Jul 01, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon SD400: horizontal lines and daylight images are overexposed (see photo)
In both the situations the problem is with the apperture control mechanism of the camera. 1). sometimes the flexible ribbion cable carrying signal to the lense assembly get worn out, replacing the same will resolve the problem. 2) in some cases the leaf blades of the apperture gets sticky, cleaning of the same solves the problem. 3). If you happen to drop the camera then the alignment of the motor moving the blades get disturbed.
In all the cases only a good repair man can fix the problem .
Jun 02, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera lense/power
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 18, 2008 | Canon PowerShot A510 Digital Camera
My Canon Powershot SD400 won't turn on and lense won't go back in
Unfortunately the lens assemblies in these compact digital cameras are quite delicate. The drop probably knocked the barrels of the lens out of alignment preventing it from moving. You can try to GENTLY twist the lens back and forth, you may be able to click it back into alignment allowing it to function normally. If the gentle manipulation fails to fix the problem you will need to get the camera serviced by a professional. There are quality repair services on the web who will work on your camera. David Millier Advance Camera Repair
Mar 05, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
