Question about Dell Inspiron 1521 Notebook
Windows Failed to load because Kernel file is missing, or corrupt
Recently, my hard drive wouldn't load because a system32 file was missing so I tried reinstalling my windows vista OS onto the hard drive. When the installation process gets to the part where the computer restarts and windows has to load for the first time it says that "Windows Failed to load because Kernel file is missing, or corrupt" any ideas on what I should do?
Also, another problem is I just bought a new Seagate 320GB hard drive and it was working great for a week then I turned on my computer with that hard drive in and it says that no internal HDD can be found. I reseated it and everything. Even tried putting it in a freezer for a while to get the disk running and everything. Please help!
  • bostianz May 17, 2009
    It's the same computer, but two different HDDs.
    The HDD with the "windows failed to load because the kernel file is missing" is a year old dell harddrive that came with the laptop.
    The seagate HDD is a new one I bought a week ago to replace the old dell HDD, but now the segate one isn't being detected by my computer, and the seagate harddrive makes a beeping noise when I insert it and turn the computer on.
    2GB Ram
    180GB HDD (the one with the kernel file error)
    Windows Vista OS
    AMD video card
    uhm idk what else to add
    Novelist:
  • 118 Answers
Are you talking about two problems on one computer? If so, the first problem doesn't matter until the second one is fixed. If you are talking about two different computers, then the problems can be each addressed.
For the hard drive that is not recognized, where did it come from? If you purchased it used, you may be out of luck. It sounds like you have a pretty good idea how computers work, and it also sounds like this hard drive does not work at all.
If these are both the same computer, then replacing the hard drive with a known working hard drive will most likely provide you with a solution.
I wish I had better news for you.
Posted on May 17, 2009
  • tony price
    tony price May 17, 2009
    What are the specs of the Dell computer?
  • tony price
    tony price May 19, 2009
    Well, I wonder if today is better for you...computers can be such a hassle.
    On many new computers, Dell's too, which run windows Vista, there is a setting in the BIOS which needs to be turned on or off during the installation procedure. this could be your problem.
    However, I am better at "hands on" with this type of problem. You will have to enter the bios and look for ACPI, or SATA functions and change them, one at a time (that is, change one, try to reinstall the OS, if it doens't work, change it back and change another one) until the OS installs properly.
    It seems like a short answer, but it is probably a couple days of work.
    As for the 320 GB hard drive, it could be that it has experienced a failure. Is it possible to connect it to any other machine, perhaps as a slave, and test it? seagate has some nice down-loadable testing software. Or, if you purchased it new, the software for testing may have come with it. Based on what your are saying, I cannot be optimistic about that seagate.
    good luck.
    tony
    New Friend:
Thanks alot vishal i did what u said and it worked ..... life saver
Posted on Dec 18, 2013
2 Suggested Answers
kalra7
  • 16 Answers
SOURCE: Windows Failed to load because Kernel file is missing
try pressing f8 when you load vista and then select start normally
if that doest not work and gives you the same error then restart and press F12 as soon as you see the dell logo, put in the vista installation disk that you got with the laptop and select boot with disk option.
try and repair or the recovery option .
NOTE : IT IS RECOMMENDED TO TAKE BACK UP OF YOUR FILES BEFORE USING THE RECOVERY OPTION .
Posted on Jun 01, 2009
\windows\system32\kdcom.dll Missing or corrupt Kernel debugger
Try tapping F8 at bootup to enter safe mode, read your manual to see if you have a recovery partition on your HDD. You didn't post the model so I have no clue.
If you can enter safe mode you need to try system restore, not last good know configuration.
If you see last know config on your screen, then you should also see safe mode.
So you need to run in safe mode, and run system restore, or run the recovery mode if you have a recovery partition on the HDD.
If none of these work, then you only have three options, go to Avira.com, download the rescue disk, burn it to a CD and run it in DOS, this is before windows boots. Now if malware corrupted the DLL, Avira will kill it, but there is a chance it can't clean it and will destroy the files,DLL, and windows won't boot. So now you have to do below.
The other option is you need to download windows, what ever version you have, if you have win 7 home 32bit, then you have to download it, and burn it to a DVD. Then try a repair, if a repair does not work then you need to reinstall windows, and then install all the drivers like, (chipset, video, sound, lan, wifi)
This option, you can contact Acer and see if they have a recovery disk for you.
Good luck.
Apr 01, 2013 | Computers & Internet
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
May 17, 2009 | Dell Inspiron 1521 Notebook
\window\system32\ntknlpa.exe
Hope its under warranty probably a failing hard drive.
Mar 12, 2009 | Acer Aspire 5610-4648 Notebook
0XC00000E9
try cleaning your Cd.
Failing that you could borrow an operating system disk to get windows up and running and then get all the drivers etc from your restore disks
Mar 09, 2009 | Acer Aspire 5610-4648 Notebook
Acer 5520 notebook startup issues
You are missing the file NTLDR.exe and NTKRNL.exe. NTLDR is the first file your computer sees when it is booting up and it brings up other files to get your computer started then it turns it over to Windows file called NTKTRNL which actually brings up the Windows operating system. The only wayto fix is to find a Windows disc and copy them over to three folders that you have either win32, windows or winnt. Copy to all three if you see all three buy only one of those starts your system and it seems like it's win32 based on your error, folder under your C: drive. That will solve your problem and your computer will boot up normally.
Dec 23, 2008 | Acer Aspire 5100 Notebook
Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
Oct 12, 2008 | Compaq Presario 1700 Notebook
How do I...
NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
Keyboard issue
Miscellaneous corruption
Corrupt boot.ini file.
Missing boot.ini file.
Missing or corrupt ntoskrnl.exe file.
Windows NT installed on a partition bigger then 7.8GB
Corrupted hard disk drive or severely corrupted Windows.
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
In the setup menu, type R to start the repair.
When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the administrator password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the
error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Once at the recovery console type chkdsk /r
Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
sys file from the cd is corrupted...try wd any other disc
Aug 02, 2008 | Compaq Presario Notebook
Dell Inspiron 1521 Notebook Logo
6,325 people viewed this question
Alun Cox
