Question about Lexmark Z715 InkJet Printer
Can't get photos to print well. Does the #90 ''photo'' cartridge replace the #20 color or the #50 black cartridge? Seems like it should be the color one, but I can't get it to snap in where the color cartridge goes.
    Problem Solver:
  • 14 Answers
The Photo cartridge replaces the black cartridge. The photo cartridge includes mono ink as well as additional colors for combination with the original color cartridge.
Posted on May 18, 2009
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge towards you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,
store the black print cartridge in the print cartridge protector or an airtight plastic
container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
electrical connections.
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
Replaced the colour cartridge with a photo one (both Lexmark) and the photo cartridge is not recognised and I'm only getting black and white printing
The photo cartridge goes in the black cartridge carrier. Keep the color cartridge in the color cartridge carrier to continue printing.
Jun 23, 2011 | Lexmark P4350 All-In-One InkJet Printer
I cant print photos on a paper they look faded when i print them and when i print a leter or words it prints really well, the printer is a canon pixma mp130...do you know what the problem might be ?
my canon mp250 won't print color photos it does well with BW but not color. I took back the first one I had did the same thing now the second one won't print color photos off the internet. what did I do wrong? Both inks are brand new.
Jan 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Won't print with just black ink cartridge
When you print, in the printing window, click properties, then click advanced. Most times you can select to print using black cartridge only. Unfortunately you will need to replace to get the printer working. If you need further assistance let me know.
Thank you,
Lee
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
How can I print a color picture without using a black catridge?
Black ink is an essential part of the printing process. The black color is only made by the black cartridge, the color cartridge does make "black".
One or more optional photo cartridges may be available, depending on your printer model.
  • Use the photo cartridge with a tri-color cartridge for best-quality color photos and graphics, and sepia or antique photos.
  • Choose a gray photo cartridge to print black and white photos with truer grays and richer blacks.
Nov 21, 2008 | HP DeskJet F380 All-In-One Printer
Printer not working!
Usually black is provided by the black cartridge only. You might be able to setup the printer through the control panel using black and white printing until the color cartridge is replaced. That might turn the color cartridge off allowing you to print.
Jul 27, 2008 | Lexmark Z1300 InkJet Photo Printer
HP Deskjet F2100 All-in-one has two slots for printer cartidges. Which of these two slots is meant for photo cartidge?
The photo cartridge replaces the black cartridge. It is used along with the color cartridge to provide better photo's.
The photo cartridge contains photo black, light cyan and light magenta while the color cartridge provides cyan, magenta and yellow. Both photo and color cartridges need to be installed and working for proper photo printing.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP Office Equipment & Supplies
Lexmark Z715 InkJet Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
