Question about Canon Cameras
Authentication code cannot find authentification code when setting up wi-fi on powershot SX510 HS
  • 13433 Answers
SOURCE: acer aspire 3000 wi fi problem
First you need to make sure the Wireless drivers are installed in the computer, aswell the Acer Related utilities. Then Most acer laptops have a button on one of the sides or on the top of the laptop to turn on the wireless.
To find out if you have the acer related programs installed, try pressing some of the buttons on the top of the laptop, that are NOT apart of the keyboard, they should open up acer or related programs, if noting happens the programs are not installed, one of the buttons is likely to turn on the wireless.
To check if the wireless drivers are installed press start -> run -> type: msinfo32 (OR press down the windows key and press R, then let go and type msinfo32 into the run menu that comes up and click OK)
On the program, left side, open up components from the + next to it, then find Problem devices from the list and click on it, on the right you will see a list of devices that are not installed or not working.
If the list is empty, everything is properly installed. and you should be able to get your wireless to turn on by pressing on the wireless button on the laptop, and then use your computer to connect to a wireless network.
If you need further assistance let me know.
Posted on Sep 01, 2009
tinualbinale
  • 436 Answers
SOURCE: Im connecting to my home WI fi and it says authentication failed
You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
Posted on Sep 12, 2009
darkpain
  • 316 Answers
SOURCE: I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
Posted on Jan 08, 2010
SOURCE: trying to enable the wi-fi on my acer 3693WLMi
install an application called 'Launch Manager' That will help. You didn't say what model? Acer Extensa 2000/2500 Series --- Far right launch button above the keyboard
Acer Travelmate C Series ---Far left hot key and then choose WLAN from menu that appears
Acer Aspire 1000 Series --Launch Keys above the keyboard
Acer Aspire 1640Z ---- Launch Keys above the keyboard
Acer Aspire 1690 ---- Launch Keys above the keyboard
Acer Aspire 2000 Series ---- Button on the front of the laptop
Acer Aspire 2012 ---- Launch Keys above the keyboard
Acer Ferrari 3000 ---- Button on the front of the laptop
Acer Ferrari 3020 ---- Button on the front of the laptop
Acer Ferrari 3400 ---- Button on the front of the laptop
Acer Ferrari 4000 ---- Button on the front of the laptop
If you don;t have the drivers go to the Acer site and download them, and install.
Posted on Feb 27, 2010
ramaly_b
  • 250 Answers
SOURCE: I have a samsung GT-G7722.
Check whether your security settings are match with your wi-fi router.
Posted on Mar 07, 2011
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Hi. Does anyone have a canon SX510 HS. If so can you please answer step step on where to go to reset the camera as my screen is blank. Like how many clicks left, right down or up. I use my camera all the...
Why do lots of people think a defective device will be healed with a reset? A camera, only has a microprocessor and a little program that runs from a flash memory. When something goes wrong in the ram part of the memory while running the program only one kind of reset exists. Just switch of the camera and one step extra, remove the battery. After replacing the battery and switching on, all software errors should be solved. Any hardware error will stay as it was.
Most settings, like switching off the display will stay as they were.
Perhaps you try pressing the display button several times, and look if the screen (display) will give what you expect.
Don't forget, if it works.
Jan 16, 2015 | Canon PowerShot SX510 HS Black Digital...
What is the authentication code for my Powershot canon Elph 340HS?
Once you connect your camera to the Canon Image Gateway site via wifi, you will see an authentication code on the camera. See Pages 87 & 88 in the manual here: https://www.manualowl.com/m/Canon/PowerShot-ELPH-340-HS/Manual/407032?page=87
Hope this helps you!
Dec 04, 2014 | Canon Cameras
My new Nexus 7 wont go past the "Select Wi-Fi" screen although I have set the Wi-Fi up
I assume you're using a secure Wifi connection with a password and it seems like that authentication is not working. You could try using an open wifi access point to eliminate the possibility of this authentication issue.
Oct 04, 2014 | Google Nexus 7
Trying to set up on the nexus 7 , but having authenticating problems
not been silly but did it ask you for the router code thats on the box,it did this with my stepsons new tablet...he eventually did it through his phone (he had internet on his htc and synced it through that)
Dec 26, 2013 | Nexus Cell Phones
Connection to the internet blacberry 9780
1. On the Home screen, click the connections area at the top of the screen, or click the Manage Connections icon.
2. Click Set Up Wi-Fi.
3. If you want to connect to a public hotspot or to a Wi-Fi® network that does not require authentication, select the Show Open networks only check box.
4. Click the Wi-Fi network that you want to connect to.
5. If the Wi-Fi network requires authentication, type a password for the network.
Feb 09, 2011 | Cell Phones
Create a new WLAN
2.Select New...
Jan 08, 2010 | Samsung Omnia Pro B7320 Smartphone
LG Incite: Connect to a multiple-user WiFi network
To enable or disable Wi-Fi
  1. Choose Start, choose Settings, choose the Connections tab, and then choose Wireless Manager.
  2. Choose the Wi-Fi button. If it is turned off, the button will appear as a lighter color and display an icon marked with an "X".
  3. Choose Done.
clear.gif To set up a Wi-Fi connection
  2. Scroll to Wi-Fi and press ENTER. The device will detect available Wi-Fi networks.
  3. Select the network you want to connect to, and then choose OK.
  4. Select Internet or Work, and then choose Connect.
    If you select a secure network, you may have to enter a network key that is provided by the network administrator.
clear.gif To edit a Wi-Fi connection
  2. Choose Menu, and then choose Wi-Fi Settings.
  3. Scroll to the connection that you want to edit, choose Menu, and then choose Edit.
  4. Make changes as needed, and then choose Finish.
clear.gif To delete a Wi-Fi connection
  3. Scroll to the connection that you want to delete, choose Menu, and then choose Remove Settings.
clear.gif To change Wi-Fi settings
  2. Choose Menu, choose Wi-Fi Settings, and then choose the Wireless tab.
  3. Scroll to the connection that has the settings that you want to change, choose Menu, and then choose Edit.
  4. Change any of the following information:
    • In Network name, enter a name for the connection.
    • In Connects to, select The Internet or Work.
    • If the network is a hidden network, which means that it does not broadcast its Service Set Identifier (SSID), select This is a hidden network.
    • If you want to connect directly to another device or computer, and not to a network through an access point, select This is a device to device (ad-hoc) connection.
  5. Choose Next.
  6. On the Configure Network Authentication screen, do the following:
    • Select the authentication and data encryption methods.
    • Enter the network key information or select the The key is automatically provided check box.
      If it is necessary, ask the network administrator for authentication, encryption, and network key information.
  7. Choose Next.
  8. Select or clear the Use IEEE 802.1X network access control check box.
  9. To use Extensible Authentication Protocol (EAP) or smart card authentication, make the selections appropriate to your choice of authentication.
  10. Choose Finish.
Aug 05, 2009 | LG Incite Cell Phone
Cameras Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
