Question about Radio Shack Pro-2018 Scanner
Need replacement antenna - Radio Shack Pro-2018 Scanner
  • Radio Shack Expert
  • 509 Answers
You can try Scanner Master dot com
Posted on May 01, 2017
2008 Malibu LTZ 3.6 engine. Diagnostic code B2470 that is an ONStar antenna issue , and P70496 I called Chevrolet Dealer, But these People have lost their minds with the prices they Quoted . ! I need to...
P70496 This is not a code . Has nothing to do with emission's .Now P0496 does P0496
Evaporative Emission (EVAP) System Flow During Non-Purge
Purge solenoid is probably bad .
Automotive Evaporative Emissions Part One
B2470
Cellular Phone Antenna Circuit Malfunction
VCIM
DTC B2470
DTC B2470 04: Cellular Phone Antenna Circuit Malfunction Open Circuit
The cellular antenna is connected to the communication interface module (CIM) with a RG-58 coax cable. The CIM polls the data from the cellular antenna once every second.
Circuit/System Testing
Ignition OFF, disconnect the cellular antenna coax from the CIM module and the cellular antenna.
Ignition ON, test for less than 1 volt between the antenna coax center terminal and ground.
? If greater than the specified range, replace the antenna coax.
Ignition ON, test for less than 1 volt between the antenna coax outer shield and ground.
Test for infinite resistance between the antenna coax center terminal and ground.
? If less than the specified value, replace the antenna coax
Test for infinite resistance between the antenna coax outer shield and ground.
Test for less than 5 ohms at the cellular antenna coax center terminal from end to end.
? If greater than specified value, replace the cellular antenna coax cable.
Test for less than 5 ohms at the cellular antenna coax outer shield from end to end.
Test for infinite resistance between the antenna coax center terminal and the outer shield.
? If less than specified value, replace the cellular antenna coax cable.
If coax cable tests normal, replace the cellular antenna.
Clear the DTCs and operate the vehicle within the conditions for running the DTC. Verify DTC B2470 does not set.
? If the DTC sets, replace the CIM.
Jan 08, 2018 | Chevrolet Cars & Trucks
Antenna does not come up
If the antenna motor makes noise, then the antenna motor is ok, and the antenna is stuck, oil it with a light lubricating oil (3-in-1, Marvel Mystery oil, store brands, etc.)
If antenna motor makes no sound, replace. Antenna motor.
I don't have a service guide for this car to help you replace the antenna motor. Usually replacing these motors are a screwdriver job, but you may need to buy a special "antenna wrench" to remove a specialized keyed nut holding the antenna to the body.
Oct 15, 2010 | 1994 Lexus LS 400
Power antenna broke and I need to replace it. How
Buy replacement antenna mast. Remove old one by unscrewing the retaining cap nut. Turn on the radio & let the antenna cable run all the way up while you pull on it to remove it.
Install the new antenna mast by turning the radio 'off' so the spool inside goes back to its beginning while you feed the cable of the new antenna down into the antenna mast hole.
Once the cable is all the way down, reinstall the retaining nut/cap and turn on the radio to allow the spool to run the antenna 'UP.'... cycle the radio ON and then OFF several times allowing the antenna to move all the way up and all the way down.
That's it!
Sep 28, 2009 | 2001 Hyundai Sonata
Broken antenna
It is not Very Easy to get to But, You can access this through the Fender Holes under the Hood. Please Rate My Response! Thanks!
Feb 05, 2009 | 2002 GMC Yukon XL
ANTENNA TERMINALS
you need to take off the antenna so that can solder the antenna terminal inside the tuner.
Oct 02, 2008 | Samsung SlimFit TX-S2783 TV
Antenna replacement
There should be a nut at the base of the antenna or in the car right under the antenna. take that off. then there might be two ways to do it. 1. you might have to run new antenna wire to under the dash board. or the antenna will need the adapter right under where the antenna sits.
Jun 20, 2008 | 1997 Nissan.5 Altima
Replacement Antenna
antennas are not so strict part of an audio equipment, you may replace with one available, with the same size, eventhough not the same length.
May 20, 2007 | RCA RCD152 Boombox
Radio Shack Pro-2018 Scanner Logo
112 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
