Question about LG 32LC7D Television
HOW DO I VIEW INTERNET ON FLTSCREEN WITH WIRELESS MODEM
Some web pages wont display
sorry FIXYa can not fix facebook problems
Oct 12, 2017 | Sierra Wireless 598U USB Modem
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Terry
Feb 15, 2011 | HP Compaq Presario F500 F700 and G6000...
Connected but unable to view website
You might need to check the security on your router , if its enable or not.
You can try the solution below to check your router wireless security. Note this should be done on a computer that is connecting to the internet thru the router.
1. open browser and enter http://routerlogin.com
2. username is admin , password is password.
3. click on wireless option .
4. look for the wireless security settings.
If you dont have another machine that is connecting to the internet. Just follow the steps below.
1. Reset your router for 30 seconds by holding the reset button.
2. turn off for 30 seconds after resetting it.
3.Power off the modem and turn it back on after 2mins.
4. If all the lights on the modem is stable power on the router, make sure the modem is connected to the internet port On the router.
5. check your computer which has a usb adapter,. Look for the wireless icon, You should be seing an option were in it will allow you to view the available wireless,
6. Look for the wireless name "netgear " and press connect. CHeck if you have internet.
Rate me if the solution is helpful
Kevin angell.
Jun 14, 2010 | NetGear WGR614 Wireless Router
Adding second laptop onto wireless internet problem
What is the problem?
What error-message(s) do you see?
What happens?
What does not happen?
Click "View Available Networks", and click to connect to the network-name ('SSID') that you defined when you did the "setup" on your wireless router.
Apr 10, 2010 | AT&T High Speed DSL Modem
Upgraded to windows 7 and i am unable to connect to the internet. I get a limited or no connectivity
I'm thinking modem/router combination. first power down modem and router. Then leaving router unplugged, power up modem, make sure it's sync up then power up router. If this is a wireless connection search for your networks name on computer/laptop..ie View wireless connection. Windows allows a automatic setup if the wireless connection is unsecured. If it is secured Windows 7 will prompt a pass phrase/ or access code. Good luck. Repeat process if necessary
Jan 31, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Cant connect cable modem
If you have phone (DSL_ the phone must be connected to the modem of DSL, then connect the ethernet cable from the modem to the wireless router or router (use the jack WAN) and then from the modem (connect the cable into port # 1) goes to your PC into your ethernet card.
You have to access to your router and set your network (you have to put the data of your internet connection gave to you by your internet provider (usually is your email address and your pass)
You can get more help here:
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
If you have a wireless network Then do this:
Setting wireless network on Win XP
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 17, 2008 | D-Link DIR-625 (790069292637) Wireless...
I unplugged the cable connected to my desktop and the wireless function stopped working
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
WHERE IS THE WIRLESS?
What does it say if you try to view the available wireless network on your laptop?
Jun 05, 2008 | Dell Computers & Internet
Vista/router/wireless connection
Make sure that all the wireless cards are set in the properties to obtain an ip address automatically, dissable the wired lan adpter connections as this can confuse the router. Restart all the pc's and then right click on the wireless pc icon in your task bar and then click view wireless networks and make sure that you are connected to your network and that the internet is available, known as local & internet in Vista. open up internet explorer, go to tools, internet options and delete browsing history cookies and temp files and then refresh the page as the proxy server will need to refresh.
Sep 24, 2007 | Computers & Internet
LG 32LC7D Television Logo
13 people viewed this question
Computer Repairing
Computer Repairing
