Question about Boating
Fuel mix ratio for 115 hp force outboard engine
Trying to find the fuel Mix ratio for my engine. 16 to 1 ? 50 to 1 ?
  • 3 Answers
50:1 ratio
Posted on May 23, 2009
I have an Evinrude 7.5hp outboard motor.Mod# 8RC1A SN# 0178194. What Year of manufd? How to mix fuel & what octane fuel to use & what oil to use? Help me go fishing, thanks.
91 octane rating ( no e-mix fuels ) and proper outboard oil ( not normal engine oil)
outboard oil has a property that allows the oil residue to stick to the metal bits and helps prevent rust
e-mix fuels absorb moisture and and rusts out steel tanks , destroys rubber components and corrodes aluminium components
the model you have is not listed on any 7.5 hp engine from 1950 to 1958
model number starts at 4434 to 7512 to 7525 in 1958
for a better answer , talk with an evinrude service center who should have a chart listing your motor
units with oil injection are 50: 1 ratio and others are 6 gallons to 1 pint of oil which is around 45:1
I would seek advice from an evinrude service center for the correct fuel to oil ratio for your engine
to mix the fuel , put the oil in first then the flow from the bowser will effectively mix it up to start with
then fit the cap on the tank and shake it up yourself
Apr 20, 2017 | Boating
1993 Suzuki 4hp 100.1 how much oil per gallon
the manual shows for a 100 :1 mix the ratio is 4 ounces of oil to 3 gallons of fuel
there are two engines and one is 50: 1 ratio so that would be 8 ounces of oil to 3 gallons of fuel
there is a pdf version workshop manual at www.motoren.ath.cx and it gives the ratios for all of the 4hp suzuki outboards and the oil to use
Oct 01, 2016 | Clymer Suzuki 2-225 HP Outboards Includes...
What is the correct fuel mix ratio?
Hi Ron:
I'm assuming we're dealing with a 2 cycle outboard, without oil injection.
Best to provide the year, make, and size (HP) to get the really correct answer.
Otherwise, most current 2 cycle engines work with 50:1
Some older outboards ran with 32:1
If you google your engine info with the key words "fuel/oil ratio" you should get the exact info.
Cheers
Apr 26, 2016 | Boating
Evinrude outboards
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Aug 30, 2014 | Garden
Why wont my 50 hp mariner start ?
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Jul 25, 2014 | Mercury Gear Set, Complete, Mariner, Force...
Fuel mix ratio for outboards
that depends on the age of the motor .if erroring it's better to have too much oil than noot enough sine that can seize an engine up
Jun 11, 2014 | Boating
My 1999 150 hp Johnson outboard skips at idle and started stalling at wake speeds. Was running fine until I tried it out for first time this year.
Fuel mix is a common cause of this kind of performance. Take special care to follow the manufactures instructions on fuel mix, most modern outboards run on100 to 1 while it is easy to continue an older mix like 50 or 33 to 1. Sometimes the mix is written on the engine cowl.
Cheers, Timo
Apr 21, 2010 | Boating
Fuel oil mixture for 1986 mercury 115
I own a small Mercury outboard so I did alittle reading in the manual and the ratio for your 86' 115 HP is 50-1. Hope it helps. Coach Theune
Oct 25, 2009 | Boating
Smoking outboard
Sounds like your running a bit rich. Try leaning down your air/fuel ratio.
Aug 23, 2009 | Sport & Outdoor - Others
Boating Logo
858 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
