Question about HP TouchSmart tx2z
Pointer will not "tap"
Pointer used to let me tap it on the touchpad to bring up things, No longer works
  • 696 Answers
This can be set to tap for you as it is a simple setting in the mouse control panel.
Go to your start menu and open Control panel, select classic view in the top left corner if there are less than 20 icons(pictures) in the menu. Now double click on the mouse icon. Click on the advanced tab. then select your synaptec device in the list and click the properties button below.
There are several options on the menu, one will say "Tap to Click"
Check the box beside it and then click OK on this window and the mouse window.
Close the control panel by tapping the pad and you're on your way.
I hope this helps Fixya,
Chris
Posted on May 18, 2009
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
The cursor jumps around on my ASUS K501J notebook.
Step 1
Step 2
2. Select the "
Apply."
4. Pick the "
Step 3
Oct 08, 2012 | ASUS K50IJ Notebook
My eMachines notebook, the touchpad is no longer working. Re-loaded drivers from web site, still not working?
For touch pad lagging, adjusting the mouse setting should fix the problem.
Select Control Panel from the start menu
double click on Mouse icon
Select the Pointer Options tab in the top
In the motion section, set the pointer speed in the middle.
And also tick Enhance pointer precision .
Click Apply and OK.
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 10, 2010 | E-Machines eMachines Desktop PC
The pointer doesnt move sometimes AT ALL
It may be in "accessibility" mode.
Tap the touchpad five times. A message will appear. Change it to normal mode, disable accessibility option.
Sep 30, 2009 | Compaq (153515-001) Touch Pad
Touchpad stopped working arrow still works
sounds like you need to adjust the sensitivity, as you can customize this to prevent accidental double taps.
you should have some software to configure your touchpad, this will either be from the manufacturer or you can use the "mouse settings" in control panel.
May 24, 2009 | eMachines E620-5885 Notebook PC
Pointer moves but cannot tap it
You should go to Start, Control Panel, and open the Mouse control settings. Locate the Touchpad settings menu. This may open a new Dell menu giving you several choices. You want to select "Touchpad settings". Inside this settings menu, you should find a checkbox that says "Tap to click". Make sure this is checked.
May 17, 2009 | Dell Inspiron 1525 Notebook
Tap function in my laptop not working
You need to download and re-install touchpad drivers to get the tapping function working.
You can download the touchpad drivers from the link below:
Select software and drivers
Mar 27, 2009 | Computers & Internet
Mouse running away
Does this model have both the touchpad AND the little eraser-head pointer affixed in the keyboard?
If so, wiggle the eraserhead pointer thoughout its entire range of motion several times. Don't be afraid of it.
No eraserhead?
Your touchpad is defective. Replace, or disable it in the bios and use an external touchpad or optical mouse. Get one that has a USB plug.
Mar 25, 2009 | Compaq Armada M700 Notebook
Laptop pointer floats across screan out of control
Is this a cXXX series Dell laptop? If so, this is a common problem with the touchpad and integrated wrist rest and bezel. You can disable the touchpad within the synaptics control panel if you use it. If you just use the windows driver, you may not be able to disable this. I will sometimes just disable both the touchpad and touchpoint and go with an external USB just so it does not wander.
Dec 19, 2008 | Intel Motherboard
Laptop touchpad is left-clicking when it is touched.
hi,
Please reduce the touchpad sensitivity. that shld take care of teh issue.
inu
Dec 09, 2008 | Gateway MT3705 Notebook
HP TouchSmart tx2z Logo
166 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
