Question about Magellan eXplorist 210 GPS Receiver
Unit will not power up on batteries - Magellan eXplorist 210 GPS Receiver
After installing new batteries it still shows on battery
ON battery, or NO battery? If ON, this could mean that the unit is not receiving power; check AC power (is unit plugged into a working outlet?), or possibly a fuse in the unit itself. If NO battery, check to make sure the batteries are good and proper polarity observed...good luck!
Jun 12, 2015 | Retail Supplies
Troubleshooting back-up malfunction after replacing battery. Checked main power supply breaker and battery power supply fuses for continuity. What should I try next?
Depending on the type of unit, you do not state any model. It may require 6-8 hours of being plugged in and turned off before the battery has enough charge that the ups will turn on.
Feb 08, 2015 | Power Computers & Internet
My Toshiba satellite P775-S7320 will not power on.
Remove the battery and power unit. Ensure there is no USB or cables connected. Insert battery and power unit. The power/battery light should illuminate. If it doesn't, the battery may be flat and the power supply not working,
Nov 05, 2013 | Acer Aspire 5100 Notebook
I need to reset my password on my lorex l154-81. Is there anyway possible to do this???
You would reset it just as you would reset the bios password on a pc. Remove cover to dvr to gain access to the inside of the unit. On the main board you will see a cr2032 battery. Remove the battery, power up the unit ( with battery out) and once the unit powers on it will say " system reset please power off". After powering the unit back off re-install the battery, power the unit back on and the system in now reset.
Jan 21, 2011 | Lorex L154-81
My hp dv 6000 will not boot up. What can I do.
shut down unit...pull power cord...pull the battery out of the unit ...reconnect power cord see if unit will start up... if it does, go to e-bay price a new battery... you have the information on battery...
shut down unit re-install battery see if it starts up...if it does unit was dropped but ok for now.
if unit does not start repeat first part,,,, order battery or bid on one or wait a while till you have the money.. or do battery pwr test...if not replace battery with a known good battery see if computor will boot if it does boot.... bad battery.
Nov 25, 2010 | HP Pavilion dv6000z Notebook
I have an IBM T40 that worked great until yesterday. When I powered it up, the 4 lights (battery, etc) flickers but the laptop does not power up. I removed the battery, paused, tried with and without the...
There are a few things left you can try. First take the battery out and make sure the unit is unplugged. Next push the power button a few times to discharge any power inside the unit. Now put the battery back in and while plugging in the unit see if the charge light comes on or flickers at all.
If it flickers and goes out, you have a bad power cord or worse a bad jack on the laptop's main board. If it never comes on, you have a bad power cord or mainboard. The battery is probably dead (doesen't have a charge left in it.)
You said this happens regardless of if the battery is inserted. Have you tried powering up the unit with no battery installed and just the power plug?
I'd see about gettting a replacement cord first. If that doesen't do it you probably have a bad board.
Oct 17, 2010 | Computers & Internet
Unit only works off battery, not AC.
there may high voltage or low voltage, ups goes on battery when high voltage and also goes on battery when low voltage acceptable range of window is 90vac to 130vac for 110v i/p
Mar 06, 2010 | CyberPower OR1500LCDRM2U UPS System
VOSTRO 1710 BATTERY WON'T CHARGE
If the battery will not charge, try this:
1.) First, power reset the unit by powering it off, unplugging it from AC power, removing the battery, then push and hold the power button on the unit for about 60 seconds.
2.) Next, plug the AC adapter back in (LEAVE THE BATTERY OUT), power the unit on. Does the unit power on?
If yes, Power the unit off and put the battery back in, let it charge overnight. If, after this the battery will still not charge, you will have to replace the battery. Contact the OEM to ensure you get the correct battery.
If no, remove the AC adapter carefully, look inside the DC port (where the charger plugs in to the laptop) you should see a small silver pin. Is this pin missing or bent? If the pin seems to be in good shape, then most likely you will have to replace the AC adapter. If it IS bent or missing, then you will need to contact a laptop repair center.
Oct 08, 2009 | Dell Vostro 1500 Notebook
CP685AVR/BF685 Power Contro.
It is likely the battery. These batteries are designed to last 3-6 years in a UPS. The good news is that if it is the battery, it is completely user replaceable and you'll have a Cyber Power unit that works just like new with a new battery. What may have happened is that the battery was weak, and you may have had a slight dip in the AC power. This caused the Cyberpower unit to switch over to the weak battery which couldn't handle the load. The unit then turned off. When you press the "ON" button, the unit will go through a self-test that checks all of the components and the unit will not turn on and be functional unless all of the components come back with a PASS, including the battery. If possible, test the battery with a voltmeter, it should read around 13.5, but not lower than 11.5v DC. However, with the unit over 3 years old, it almost certainly the battery. Here's a link to a replacement battery for the CP685AVR: http://www.batteryinternational.com/cyber-power-cp685avr-ups-battery-ups-batteries-f1.html
Hope this helps.
Jun 28, 2009 | CyberPower (CP685AVR) UPS System
Unit does not back-up (stay on-line at all) when power goes out.
If the battery is over 3 years old then it most likely needs to be replaced. Since it works fine except for when it is relying on power from the battery, then a new battery should make it just like new. http://www.batteryinternational.com/ups-batteries.html should have the battery you need. Hope that helps.
Apr 16, 2009 | CyberPower 525SL (CPS525SL) UPS System
Magellan eXplorist 210 GPS Receiver Logo
32 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
