Question about Pyle PLCM7300BT Mirror Monitor
Pyle PLCM7300BT Installation
Are there any good instruction for installation?
4 Suggested Answers
SOURCE: what is the passkey for a pyle 7
The passcode is 8888 I sure hope that someone has answered this before this time.
Posted on Nov 26, 2010
SOURCE: can you provide some install
only step that is missing is the red wire one the camera.Use the adapter that is in the kit and attach it to your back-up lights this is used for your night LED's
Posted on Dec 21, 2010
  • 11800 Answers
SOURCE: As far as the Pyle
They installed it incorrectly: the unit should have been powered from the reversing lights, this way it would have been active only when the reverse is engaged. Instead they have powered it directly from the main contact so it stays permanently on.
Go back to the ones that installed it for you and ask them to do their job properly, to power it correctly.
Posted on Jun 02, 2011
How can I get the install instructions for PYLE PL7300BT Rear View camera system?
Pyle PLCM7300BT Mobile Video Navigations Back up Camera Rear View...
Went to this site to find your particular product,it has a downloadable pdf manual whic will by default show you your setup.You may not have the green wire but if you read this manual you may be able to by process of elimination figure out your question.Pyle also has a very good technical support staff,been there done that ,they will also help you out.Good luck hope this helps you.
May 19, 2014 | Pyle PLCM7300BT 7"TFT Mirror Monitor W/...
How do i install my Pyle PWD701 4-Button Remote Door Lock Vehicle Security System
Referring you inquiry directly to Pyle could yield installation instructions
Sep 03, 2013 | Pyle Home Security
Installation instructions for pyle view plcm7200
Where do I hook up the green wire on Pyle 7200 rear view camera
Dec 27, 2012 | Pyle PLCM7200 7'' Tft Mirror Monitor W/...
Pyle plcm7300bt what does the green wire reverse car wire connect to + or ground
The green wire connects to the backup lights control. When the gear shift is in "Reverse" this acts as the switch on the "Monitor" and turns the system on so you can see what's behind you to safely "Backup" Hope this helps you.
Jan 09, 2012 | Pyle PLCM7300BT 7"TFT Mirror Monitor W/...
Idont have no instrutions to innstall the unit plase help me thanks O J
Please what is the name and model of the unit that you don't have instructions to install?
Please verify.
I look forward to your reply.
Bye for now.
Apr 28, 2011 | Pyle PLCM7300BT Mirror Monitor
There is a black power cable with two leads for the power for the camera but I don't have in the instructions what to do with it
This is how to hook up the Pyle PLCM7300BT:
On the license plate camera, plug the black cable provided with 2-wires inside (one red and one black) to its counterpart on the camera. On the open end of this black cable, strip and connect the black wire to the car/truck metal body part.
Connect the red wire from the camera and the green wire from the monitor (part of the big black cable from the monitor) to the power wire to the back-up lamp socket.
Connect the Red wire from the monitor to a switched terminal on the fuse box so that it would only have power when you have the ignition key on.
The rest of the wiring is simple and common sense.
To operate, turn on the ignition of you car/truck and put it on reverse you should see the camera view. Put the car/truck on Park, the monitor screen should go back, if not, push the power button once.
To set up the blue tooth: Push the power button on the monitor so that you can see the blue screen and "no Input". Put your phone on discoverable mode and push scan for device. AT the same time push the "pair" button on the monitor.
I did all the figuring out on the bench using a 12 VDC power supplies and contact switches to make sure I understood how it worked. Once installed on my 1988 Suburban, it worked as expected.
The only problem I had to patch the long green wire (reverse car) so that it reached the back-up light socket.
Let me know if you still have problems. Email me at wayne.tan@wdc.com
Wayne Tan
Feb 24, 2011 | Pyle PLCM7300BT Mirror Monitor
Can you provide some install steps to the pyle view plcm7300bt?
Dec 20, 2010 | Pyle PLCM7300BT Mirror Monitor
How to install, since it doesn't come with instructions.
Unless your speakers / boxes are specific for your car, there will not be any installation instructions beyond generalized that may include a wiring diagram, a chart to show how much volume your speaker box needs (minimum and optimum), power handling, etc.
Search for your model / part numbers at Pyle Car Audio and see what information is available there.
Sep 18, 2010 | Pyle Car Audio & Video
What is the passkey for a pyle 7'' rear view monitor bluetooth- plcm7300bt?
Jun 20, 2010 | Pyle PLCM7300BT Mirror Monitor
Pyle PLCM7300BT Mirror Monitor Logo
41 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
