Question about LG Flatron 23" Super Led Lcd Ew234 1080p High Definition Monitor Excellent Cond
Flatron ew234 how to turn the sound one
I connected a flatron w1952tq to my computer and I have video but no audio. How do I fix it
do you have speakers on your monitor? If yes, check the wire connecing hte sound to the speakers
Jun 11, 2014 | LG Flatron L1951S-SN 19" LCD Flat Panel...
How to turn on sound for Flatron IPS235
flatron functions only as video monitor, audio is run or provided through a separate device connected to CPU computer or other sources connected to video player.
Feb 21, 2014 | LG Computers & Internet
No sound on my '03 lg plasma flatron tv., model : DU-50pz60
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Apr 01, 2012 | Televison & Video
My lg lcd 22' flatron just turn green,i can still use it but i had to get use to its green display, what should i do to make it back to normal??? pls. help....
Have you tried taking out the connecting VGA cable and putting it back in? (Sounds silly but sometimes works!) Also, can you try using a different cable to see if it is a cable fault? Try the monitor on a different PC/laptop and then you can tell if it is a fault with the PC or the screen.
Jul 26, 2011 | LG 22" FLATRON LCD Monitor
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
How do I turn the monitor in
It sounds more likely to have power supply failure if you hit the power button and it does not turn on.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply. You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 02, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
Hi, I have an LG Flatron TV which I bought 6 years ago. Good picture, no problems until now. I put the set on standby via the remote. Later, when I put it on via the remote all I got was sound and no...
Since the screen keeps turning off and sound only remains have a look at the inverter board for any buldging capacitors which look like blue cans, there is most probably a short in the inverter and the powersupply is sensing this thus turning it back into standby to prevent damage to the tv.
jonno
Nov 04, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My Lg TV is not displaying picture just a single line
If you have sound the problem is most likely the LCD panel but if you have no sound then it is going to be the main board.
Oct 11, 2009 | LG Flatron W2242P-SF LCD TV
LG Flatron 23" Super Led Lcd Ew234 1080p High Definition Monitor Excellent Cond Logo
26 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
